The old igniton system was then removed. It included the igniton module on the right and the coil in the middle along with a 45D.
The 25D was installed to check it was working correctly and set the base timing. As the new Stealth unit would be managing the advance timing the base timing was set to TDC. The distributor now acts as a crank angle sensor
I dug out the old laptop we had lying around to see if I could install the accuspark program on it. Getting the program running and the blackbox to communicate to the computer took longer than swapping the distributor! A basic timing map was loaded on the unit to start with.
Next up I installed the blackbox, it has four wires (distributor, coil, earth, positive) so even I could manage it! It is currently temporarily mounted under the dash until I've finished tuning it. It's funny seeing the USB port in a 1960's car too!
I've also rerouted the mechanical temp gauge tube and it's much tidier now under the bonnet.
It ran really well on the test drive and it's now very easy to make changes to the igniton timing
