1964 Mk1 Morris 850
853 replies to this topic
#271 timmy850
timmy850
  • 3,290 posts
  • Local Club: MITG
Posted 25 March 2016 - 10:45 AM
We had a run a couple of weeks ago which was fun, and had a reasonable turnout.
#272 Vinay-RS
Vinay-RS
  • 2,111 posts
Posted 25 March 2016 - 04:39 PM
I love the fact that there are so many mk1s in that photo :) They are a lot less common on our local runs.
#273 timmy850
timmy850
  • 3,290 posts
  • Local Club: MITG
Posted 28 March 2016 - 10:31 AM
We had the Mk1 in production from 61 to 69, the Mk2 (which looks essentially the same) from 69 to 71, and then the clubman front came out in 71 to 78. Mokes were made 66 to 81..
We normally get mostly Mk1's, and a handful of the rest on the runs
#274 timmy850
timmy850
  • 3,290 posts
  • Local Club: MITG
Posted 13 April 2016 - 04:04 AM
I took the mini for the yearly registration check this morning and it passed with no problems. I'll be getting the registration swapped to "Historic" number plates, which is much cheaper, but still lets me use it 60 days a year.
I've also picked up a set of adjustable lower arms and tie bars for the front, so once the cones settle in I'll get them fitted and get a proper alignment done  :D
#275 simpsonsclassics
simpsonsclassics
  • 106 posts
Posted 13 April 2016 - 05:53 AM
Just had a read through this what a great car. You must be very happy with it :)
#276 timmy850
timmy850
  • 3,290 posts
  • Local Club: MITG
Posted 22 April 2016 - 05:28 AM
Thanks!
Here are the (new) suspension arms. Apparently they had been fitted to a car but not used. I'll need to grab a couple of new bushes before I can fit them.
After the car passed the annual inspection I swapped the registration over to "Historic". This means I can drive the car 60 days a year in addition to our club's events. The best part is it costs $95 instead of ~$860 for the year! This price covers the annual registration cost (about $260) and the CTP (Compulsory Third Party Insurance $600). They issued a new licence plate, which is much smaller than the old one, and looks a bit funny with the long flap on the boot.
As it gets hot here the engine sometimes feels like it is down on power when it is over 30 degrees outside. I thought a cold air intake might keep the temperatures under control, and I found some ducting large enough to suit. I'm going to make a couple of brackets to get it in and out easily depending on the weather.
#277 timmy850
timmy850
  • 3,290 posts
  • Local Club: MITG
Posted 21 June 2016 - 03:11 AM
I picked up a km 850 speedo for my birthday this year. These were fitted to Morris badged cars exported to Europe.
Not only does the speedo work correctly and show km instead of miles, but the odometer works properly too! That's a first for me since having the car.
The new smaller number plates at the rear looked a bit funny with the wide flap on the boot. I ordered some blank UK size plates from eBay and they were exactly the right size to surround the new plate.
They look pretty good now, and just need to be bolted together. Australian cars changed to a shorter, taller number plate size on the boot to match local sizes a year or two after my car.
I had a go on the weekend at putting on the new front end adjustable bits. I bought a new set of standard rubber bushes to replace the ones that came on the arms (they were previously installed on a car but not driven on).
With the old tie bar removed, it was obvious how bent it was.
The old tie bar and lower arm bushes were also pretty dead.
It was pretty straightforward to swap them over. The most recent mini magazine I bought had a step by step guide too, which was handy!
After it was all back together I did a quick lap around to settle the suspension and make sure nothing was wrong. One side had approx -0.6 degrees camber and the other side was -1.6 (measured with an iphone app  :lol:  ), so I did a little adjusting to get them to around -1.0. The toe on the wheels then looked a bit out, and I measured about 30mm of toe out! The tie rod ends were the normal length ones, so I ran out of thread to get it in the ballpark. I've ordered some long ones, so once I can get them on I will get a proper alignment done.
#278 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 21 June 2016 - 03:07 PM
That's a classy looking speedo there Timmy, I likes it.
#279 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 21 June 2016 - 07:20 PM
Lovely speedometer  =]
#280 James_eaton_thewholething
  • 1,063 posts
Posted 21 June 2016 - 08:30 PM
I love this little car.
I remember the first time I had to change tie rods, the bolt that held it on had weld it's self into the lower arm so had to replace that as well
#281 GT Jimmy
GT Jimmy
  • 1,639 posts
  • Local Club: S.U.N.M.C
Posted 21 June 2016 - 09:14 PM
I love your mini mate, looks great.
Look what I found in sunny Manchester, never been on an engine, an Aussie timing cover
#282 timmy850
timmy850
  • 3,290 posts
  • Local Club: MITG
Posted 22 June 2016 - 01:25 AM
Thanks. It makes a big difference having new glass and chrome, and having a new needle that is clear and not yellowed.
Cheers!
Luckily mine were all fine. The only problem I had doing the swap was breaking the ball joint separator when starting on the right side which was a real pain...
Cool, it's one that was pressed in the factory here. They stamped numerous locally made parts with that logo, including rocker covers (which Jared should know..)
#283 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 22 June 2016 - 04:29 PM
I do indeed  :proud:
#284 timmy850
timmy850
  • 3,290 posts
  • Local Club: MITG
Posted 27 June 2016 - 09:59 AM
The boot had quite a few holes in it from various different plates over the years..
One more set of holes (hopefully the last!) and some bolts and it's looking good
They are actually metallic black, so they can appear black/silver/white depending on the light
I thought a matching set for the front would be good, as it helps to hide the bracket
I've also picked up a bargain 12G940 head, just for a rainy day...
#285 Vinay-RS
Vinay-RS
  • 2,111 posts
Posted 27 June 2016 - 11:08 AM
That is one of the GT (GTS here) heads with the larger valves right?
I do like the new number plates. The larger plate that fills the numberplate holder is a nice touch :)
