1964 Mk1 Morris 850
858 replies to this topic
#196 JewSkii
JewSkii
  • 218 posts
  • Local Club: Looking For One
Posted 02 August 2015 - 11:28 AM
Umm i just noticed the gauges too they look good
#197 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 02 August 2015 - 09:54 PM
Quite liking those extra gauges where you have put them :)
Thanks guys. I can't claim any credit though, my dad installed the gauges there in the 80's. They were originally a water temp, oil pressure and ammeter in three different brands. Now I've got a water temp, oil pressure and manifold vacuum, all with mechanical senders.
#198 70K1100
70K1100
    Formally Known as NOT850
  • 233 posts
Posted 14 August 2015 - 04:33 AM
How are you going piecing together the 1100 for your mini?
#199 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 14 August 2015 - 07:18 AM
I've got:
A couple of engine blocks suitable for re-boring. Probably going +080 or +100 thou oversize.
A couple of cylinder heads suitable for new valves and porting. One 202 head looks almost brand new
A good crack checked and reground 1098 crank and an unknown spare I haven't pulled out of a motor yet
A 4 synchro remote box and three rod change boxes for parts
Rebuilt set of HS2 twin carbs and airbox with all the linkages. I've also got an HS6 if I decide to go single carb
A cam away for grinding.
Still need to buy the pistons, engine and gearbox rebuild kits and I'll probably need a disc brake kit too!
I haven't been spending much money on it recently as we've recently moved into our new house. If I didn't have to pay the mortgage for a couple of months I could have it all finished... The old 998 has been running like a champ recently too, so I'm a bit hesitant to pull it out  :D
I've got the hilo kit to go in next, hopefully I can do that this month...
Edited by timmy850, 14 August 2015 - 07:19 AM.
#200 70K1100
70K1100
  • 233 posts
Posted 14 August 2015 - 11:32 AM
Are you going to run the cooper s brakes or the cooper setup so you don't have to add flares?
#201 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 17 August 2015 - 05:01 AM
I did have a set of front hubs and drive flanges from a Cooper. I ended up selling them as I didn't think it was worth the time and money to get them working again. By the time I replaced the wheel bearings, ball joints, discs, calipers, etc I'd end up with brakes not much better than what I have now. I think I'll just buy another set of wheels to suit the disc brakes when that time comes.
#202 70K1100
70K1100
  • 233 posts
Posted 20 August 2015 - 11:18 AM
How does you mini go with the all drum brakes? Do you have any problems with pulling up straight and in enough space?
#203 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 20 August 2015 - 11:46 AM
The drums brake are perfectly fine for the car at the moment. I haven't had any issues or fading driving the car in normal traffic or mini runs. They just need to be adjusted up every now and then.
#204 70K1100
70K1100
  • 233 posts
Posted 21 August 2015 - 11:00 AM
I've read your post a few times and I've enjoyed it and found it informative as well. I've got a Mini K and trying to rebuild it on a budget rebuilding the drum brakes is cheaper than upgrading to Cooper S discs is a lot more expensive.
#205 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 24 August 2015 - 12:59 AM
I'll be definitely be upgrading the brakes when I do the engine. I drove a mini with a booster and discs over the weekend, and the difference is huge, especially when you have more power. The best price for a disc conversion I've seen in Australia is at Karcraft, and they are about $970. It's much cheaper buying it as a full kit than in pieces.
#206 70K1100
70K1100
  • 233 posts
Posted 24 August 2015 - 06:05 AM
That is a very good price for the conversion kit. Does that include everything that you require to change from drums to discs?
#207 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 24 August 2015 - 07:10 AM
That's the price for the minispares brand calipers (as of the start of the year). Getting a set delivered from the UK is approx $1080 now the dollar has gone down...
http://www.minispare...-AJJ4028MS.aspx
#208 70K1100
70K1100
  • 233 posts
Posted 24 August 2015 - 01:22 PM
I've been checking out a few different suppliers and Minispares to my door for their kit is about that price. I will have to track down my copy of the Karkraft catalogue again and check them for pricing. DSN were a little bit cheaper for their kit but they were out of stock.
#209 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 24 August 2015 - 10:24 PM
I've got the 2015 Karcraft one I can email you if you send me a PM with your email address. Remember it's possible they can slug you with GST on online orders over $1000..
#210 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 28 August 2015 - 02:51 AM
I'd been looking for some wheel caps for the alloy wheels. I found some Ford ones at the wreckers which looked like they should fit..
They fitted pretty well, they just need some new logos and a polish up.
I started installing the Hilo kit I bought too. I'm doing the rear first just to level it out a bit, and I'll put the front ones in later when I get some new rubber cones.
I started on the right side and it was very straightforward, except for the nylon cup in the arm which took ages to get out. It came out in many pieces, the largest one being this one. It hadn't worn through, which is a good sign.
Here is the right side done
The left side was a bit more challenging as the tank needed to be moved to get to the shock. What most guides don't mention is that early tanks have a long drain valve at the bottom... Luckily mine had been trimmed short enough to get a socket on as stock they are pretty long! http://minikingdomon...tube-fuel-tank/ . It's tucked right up near the rear exhaust hanger too, so it's a pain to get to..
I got the drain valve off and the fuel was only slowly dripping out, so I slid the tank over and put the valve back in.
The rear cones on both sides are in pretty good nick too, they still have glossy paint! They will need replacing at some stage as they're the original Moulton/Dunlop ones
The left nylon cup came out in one piece, along with a bunch of ancient road dirt and mud from the subframe
Here is the stock trumpet against the new hi-lo. I got the left side in and did a quick height adjustment to get it reasonably level. They'll need a little adjusting once they bed in properly.
I then had to move the tank back over and secure it in place. I undid the drain valve again, but this time the slow drip had turned into a fast stream. I ended up draining the tank completely as I couldn't get the valve back in from the bottom without getting covered in petrol...
I pushed the car out to give it a quick wash to get rid of the spilled petrol and I heard a little scrape
The exhaust is now scraping on our tiny driveway! It's due to the fact I had to tweak it a bit to get the exhaust pipe to miss arcing on the floor start button. I might have to get some exhaust wrap or something so I can push it up a bit higher safely...
I'm booked in for a big car show on Sunday, so I'll get some pictures then if all goes to plan!
Edited by timmy850, 30 June 2017 - 10:27 AM.
