Also try TotalMINI.com
http://www.totalmini.com/forum/
R50 MINI 2001-2004 have the Rover Midland gearbox which can suffer from bearing problems, from the mid-2004 onwards R50 'facelift' models a stronger 5-speed Getrag gearbox was fitted. The R53 2002-2006 Cooper S alway had a bullet proof Getrag 6-speed gearbox from day one.
If you need a recon MINI gearbox this company will swap it while you wait:
http://www.minigearboxes.co.uk/
If you find a good early MINI with a Rover gearbox change the gearbox oil (MTF94) to prolong its life......BMW said it was 'filled for life' like many modern cars but out of warranty there is of course no compensation if it fails due to noisy bearing wear. When the gearbox fails it sounds like a helicoptor.......I have an original Midland box in a 2002 MINI which has had regular oil changes and has a very slick gearchange. Many say a good Midland box has a nicer less clunky gearchange than the later Getrag box. It is possible to fit the later gearbox to early MINI's but you need to change mountings, clutch and driveshafts, etc to suit from a later model.
Lots of info here:
http://www.totalmini...nd-gearbox.html
These early MINI Buyers Guides may also help:
http://www.aronline....mini-2001-2007/
http://www.motoringf...3-buyers-guide/
Edited by mab01uk, 17 November 2013 - 05:53 PM.
