Mounting Stack Wheel Speed Sensor (St670)
16 replies to this topic
#1 Deejayry
Deejayry
  • 70 posts
  • Local Club: NIMFOS <--We dont do clubs!
Posted 17 November 2013 - 02:01 PM
Have any of you here installed a stack speedo or dash display on your mini? If so could you tell me about how you went about installing the wheel speed sensor?
I have been thinking about buying a stack dash display for a while and my only concern is how to mount the speed sensor.
Thanks.
#2 phil hill
phil hill
  • 616 posts
Posted 17 November 2013 - 04:48 PM
I ended up using a speedo drive sensor from these guys : http://sailesmarketi...x4h-transducer/
It's a speedo sensor from a London Taxi but I asked them to replace the spade drive for a square drive so it would fit the mini gearbox.  From memory it was about £35 with next day delivery, the flex is two metres long (three core mains flex actually, but easy enough to wire up to the Stack).
Unfortunately I don't have the email contact any more as I've changed company and therefore lost my email history, but it was simple enough when I got to speak to an actual person.  Nice easy solution too : no magnets, no glue, no brackets...........
I'm sure there are other companies who offer this kind of sensor now, maybe one of the companies supplying electronic speedo's or Rally type trip meters ??
Sensor :
Mounted on Gearbox :
In-car :
Phil.
#3 summs116
summs116
  • 372 posts
  • Local Club: Mini 7 racing
Posted 17 November 2013 - 07:42 PM
I ran a sensor on the rear back plate and quicksteel the magnet on the rear hub.
#4 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 17 November 2013 - 07:48 PM
I did the same as the above, but that sensor is brilliant in the first reply!
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 17 November 2013 - 09:18 PM
Phil, is that the same sensor you installed back in 2010?
#6 The Principal
The Principal
  • 763 posts
Posted 17 November 2013 - 09:21 PM
never used one but came across this the other day - https://www.merlinmo...18x1-5-sp-trans
#7 phil hill
phil hill
  • 616 posts
Posted 17 November 2013 - 09:51 PM
Hi Doug.
Yes it is, and It's still going well even after a dousing in Pot-joint grease after I had a seal failure !!
Phil.
#8 phil hill
phil hill
  • 616 posts
Posted 17 November 2013 - 09:54 PM
Same sensor, but wrong mounting thread.  The thread on the FX4 sensor is correct but the FX4 has a rectangular drive rather than a square (If Doug can find the original posts I send him in 2010 he will have the details of the thread and the guy at Sailes I spoke to).
Oh and the price seems to have gone up by a lot !!
Phil.
Edited by phil hill, 17 November 2013 - 10:06 PM.
#9 phil hill
phil hill
  • 616 posts
Posted 17 November 2013 - 09:58 PM
Here's the original thread details : http://www.theminifo...x4#entry1275035
Phil.
#10 grumpy dad
grumpy dad
  • 305 posts
Posted 17 November 2013 - 10:02 PM
Try this
http://www.donbarrow...tripmeters.html
near the bottom of the page
and only 30 quid
#11 phil hill
phil hill
  • 616 posts
Posted 17 November 2013 - 10:10 PM
Try this
and only 30 quid
Yep, but still the wrong thread to fit a mini gearbox.
It maybe close, I seem to remember it's a weird thread like 7/8ths fine or some-such.
Phil.
#12 grumpy dad
grumpy dad
  • 305 posts
Posted 17 November 2013 - 10:15 PM
Hi
it fits for me on a mg midget box
and fitted a mini cable to the out put
#13 phil hill
phil hill
  • 616 posts
Posted 17 November 2013 - 10:17 PM
Hi
Oh, ok !!  Maybe M20 fine is close enough then !!
Phil.
#14 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 18 November 2013 - 12:21 AM
M20x1.5 should not fit well and may come loose over time.  Before I learned what the actual thread size was I made several metric ones threaded 19x1 and those do fit the gearbox fairly well with positive thread engagement.
The common gearbox speedometer cable thread is 3/4-26 and was on most British gearboxes from the 1960s and 1970s until some cars started using a cable that was held to the gearbox with a clamping fork/foot similar to (but obviously smaller than) the fork used to hold the distributor in place on an A+ engine.  The other end of the cable has a metric 12x1 thread to the back of the speedometer.  As with the lower cable end, sometime in the mid- to late-1970s they changed the type of upper connector to the speedometer head.
Looking through my old emails, the contact I had with Sailes was with a man who only identified himself by his first name, "Matthew".  The current model transducer appears to be the FX4H.  As Phil said, it comes with a rectangular drive key that is not right for the hole in the Mini gearbox.  However, Phil said they made a square drive version for him so I am sure they could do it again.  The link below (if it works) is for the Sailes FX4H speedometer transducer.
#15 Deejayry
Deejayry
  • 70 posts
Posted 28 November 2013 - 04:31 PM
Thanks all for the replies, I like the idea of mounting the  ST670 on the rear back plate, does the sensor have to detect a magnet? i was under the impression that it simply detects moving ferrous components, so in my situation where i have used alloy rear hubs could i simply set it to detect the wheel studs?
I do like the idea of the gearbox mounted transducer, does using this mean that i would have to order the version of the dash display containing the ST492 pulse amplifier? My only concern is the calculations to calibrate the speedo, according to the manual the speedo is configured by entering wheel circumference and number of pulses per revolution, can anyone elaborate on how you set it up?
