Whilst i am certainly no expert I would have thought a welded seam along the top edge/flange of the sill to the doorstep/rear wing edge would be weaker than a series of good spot/plugs. Welded along the edge would not ensure the two flanges are correctly held together and would in theory give some flex to the area. When I took off the sills on mine which had been welded along the edge they came away easily once the underside welds had been ground off the inner sill. I thought at the time how weak this was compared to the section I took apart which had been spot welded properly.
I am lucky my mot man is a classic car man and knows what makes a decent repair and give allowances for the somewhat bigger variances in old motors compared to the modern boxes.
As said before if you repair this well and paint and stone chip it can't see how the hell they would be able to tell. You certainly can't on mine now ;)
Cheers Glyn
I know what you are saying, but the ease of removal is more probably down to how accessible the welds are rather than their strength. The seam weld is much easier to grind down than a spot weld. With a decent spot weld drill you would be amazed how quick they fall apart and you might be lead to think the other way!
I think the key point is to find a MOT man who understands old motors as mentioned ^^^^^ and in my previous post. That way you are far less likely to get some over officious interpretation of the rules. At the end of the day that is all it ever is - an interpretation, there will always be variance between testers.
