i need new sills and have been told spot welding now not allowed on anything structural like sills and will now cost £200 to weld a pair on
is this right?
Posted 12 November 2013 - 10:20 PM
is this right?
Posted 12 November 2013 - 10:36 PM
eh! thats how they were fitted from the factory! Can you describe exactly what your plans were and what you have discussed with the tester?
Are you trying to patch up sills or use over sills or are you intending on removing and replacing sills. (really from an mot point of view either if done to a good standard should be ok although to give a longlasting and neat repair you must cut and replace sills along with any rust which you find underneath.
Edited by robminibcy, 12 November 2013 - 11:23 PM.
Posted 12 November 2013 - 11:04 PM
Posted 13 November 2013 - 07:52 AM
thanks ,i was planning to replace totally as there are holes front and rear of sill he said they have to weld a full run along both edges, i asked cant he just spot weld the full length and weld up the ends ?
no as its below a certain height and structural spot welding isnt allowed?
thing is i was planning to put the chrome trim along seam which would cover whatever welding was used eh
Posted 13 November 2013 - 07:53 AM
I wonder if he's ever tried removing factory fitted spotwelded sills !!!!!
Posted 13 November 2013 - 09:24 AM
Load of rubbish, most cars are still spot welded to my knowledge, I know my new Ford Ranger is spot welded all along the bottom of the tub i.e. the floor to the sides, it's technically the proper way to do it as it's how every one came out of the factory.
Posted 13 November 2013 - 09:30 AM
Posted 13 November 2013 - 09:40 AM
I'm sure someone can quote the tester's manual so it can be explained in simple terms to him. Welds should be the same as the originals, plugs equate to spots. It's only where bits are joined where there wasn't originally a join that it stipulates a continuous seam. You could even argue that only applies to what's considered structural - maybe that's where his confusion comes from, could legally patch up your wings with cornflake box 'n gaffer tape.
Posted 13 November 2013 - 10:39 AM
Posted 13 November 2013 - 12:32 PM
My normal MOT guy was away last year so went to the garage next door to the local mini-centre.
He failed me for my spot welds on the sills. Said they were too far apart and should be seam welded as its a structural panel. Did not expect that considering it had passed fine in previous years!
So had to add more weld and ruin my professional paint job
Next time I will remember to put the sill trim on!
Posted 13 November 2013 - 12:33 PM
Also, how on earth do you seam weld the vents on normal/factory sills then?
Posted 13 November 2013 - 12:36 PM
Posted 13 November 2013 - 12:50 PM
Posted 13 November 2013 - 06:59 PM
load of tosh if they are correct sills, and welded correctly its a pass end off, all patch repairs do have to be seam welded
