Accelerator Sticking ...
Posted 12 November 2013 - 06:42 PM
Any help much appreciated !
Josh
Posted 12 November 2013 - 06:46 PM
Could also be the routing of the cable and wear in the Carb
Posted 12 November 2013 - 06:47 PM
It's a hif38 carb if that's any help
Edited by josh austin mini city e 82, 12 November 2013 - 06:49 PM.
Posted 12 November 2013 - 07:01 PM
It doesnt have to rub on the bulkhead and dont be tempted to grease the cable.
Remove it and inspect it, it may be kinked or corroded, and use WD40 if you want to clean it and keep it lubed.
Posted 12 November 2013 - 07:04 PM
Ok I'll take the cable off and have a look, it is brand new thoIt doesnt have to rub on the bulkhead and dont be tempted to grease the cable.
Posted 12 November 2013 - 07:10 PM
It can happen on a brand new cable (ie rain dripping some dirt over the cable if it sits loose on the bulkhead connection, or it can be even kinked while fitting)
Posted 12 November 2013 - 07:13 PM
have you used the std replacment cable or did you go for the nylon sleeved special tunning cable......the latter is the best on the market and DOES not stick........you say you checked the pedal have you got down and looked where the cable goes through the body into engine bay....and check if the hole is clear and you removed the old brass cable end from bay side I had this prob as when I tried to insert the new cabls I did not realise the brass end was there and the new cable would not seat correctly and this binded on each other.......
Posted 13 November 2013 - 07:43 AM
