thanks mate, the only problem with this for me is the fact i don't know what a lot of actually means for example a knock sensor lol
Posted 01 March 2014 - 08:18 AM
Posted 01 March 2014 - 08:24 AM
If you list the ones off that pic youre not sure on. I'll try get pics of mh engine where they go.
What loom are you using for the rest of the car? And what clocks?
thanks mate, ill do my best, I'm taking the engine out on sunday night again so i will get it done then
the one thing i really don't know of, do i need pic 8/9? thanks again
Posted 01 March 2014 - 08:46 AM
Posted 01 March 2014 - 09:00 AM
Edited by DangerousDave17, 01 March 2014 - 08:18 PM.
Posted 01 March 2014 - 08:15 PM
Its the iab - inlet air bypass... The ecu controls it to open a secondary set of butterfly valves (inside the standard ecu) at high rpm. The skunk manifold doesnt have them.
that clears that up lol so what do i do wit it? just cut it off?
Posted 01 March 2014 - 08:20 PM
Posted 01 March 2014 - 10:13 PM
Hello Hegnirst
Build is coming together nicely, i wish the most amount of luck heading forwards. Shouldnt be long now with the pace your setting
Regarding your wiring labelling I've tried to figure out as many as I can, I didnt use the main interier loom, aslong as you can trace where the wires go from the engine to the ecu, relays and fuses then you should be fine.
1. Passenger side connectors, 4 pin one is for injectors
2. Earth for somewhere, possibly rocker cover
3. Lambda Sensor
4. Idle Air Control Valve (back of inlet)
5. Possibly knock sensor
6. Throttle Position Sensor, MAP, Speed sensor
Next post
2. Passenger side connectors
3. All orange plugs are ABS
27. Dizzy connectors
Links:
http://www.16vminicl...read.php?t=8081
http://www.16vminicl...ead.php?t=28430
Hope this helps
Regards
Kieran
The bit I don't get is what I. Don't get is how or where do I connect the lights too and the indicator too? And stuff like that? Lol
Posted 02 March 2014 - 12:10 AM
Posted 02 March 2014 - 02:05 PM
I cut mine all out as it had been bodged so many Times over the years! Lol
Posted 02 March 2014 - 05:22 PM
Yep the above loom assumes you are using the mini loom for all the mini stuff. This is what I am doing any way.
Edited by Sleepy Stu, 02 March 2014 - 05:22 PM.
Posted 02 March 2014 - 05:46 PM
Posted 02 March 2014 - 09:01 PM
Yea, I'd recommend you get a replacement mini loom. Much less work than using the Honda one for lights etc.
Well I have got my old loom still I just wanted to start afresh lol no way I could do this? As it must connect up to the loom somehow because there's a fuse box with lights on it etc
Posted 02 March 2014 - 09:19 PM
Posted 02 March 2014 - 10:30 PM
You 'could' do it if you wanted. Eg. Use the complete honda loom - shorten it all, re route it, change all the connectors etc.
But if you use your mini loom with the Honda engine loom there's only a few wires to connect. (12 live, ignition live, earth's etc) for the ecu to work.
hmmm i wasn't going to use the mini rockers but i suppose i could to be fair lol you make it sound soooo simple lol I'm no nearer to sorting out the wiring for the honda loom lol i need someone who's done the conversion before or similar and just have a list of what i need for the engine to run etc. I'm going to have a look at my mini loom tomorrow morning before i go to mini spares for brake lines
