* * * * - 1 votes
Bruce the clubman 1972
362 replies to this topic
#181 Hegnirst
Hegnirst
  • 3,496 posts
  • Local Club: Hilltop Minis
Posted 30 December 2013 - 02:45 PM
Long bit - http://www.minispare...|Back to search
Short bit - http://www.minispare...|Back to search
Then just use the standard bolt. Jobs a good un!  Theres a bit more info in my build thread somewhere
i must be completely with you mate ive never actually had a strap in petrol tank lol so i have no idea how it attaches to the car lol does it bolt on or?
thanks by the way :)
#182 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 30 December 2013 - 02:47 PM
Not even the standard tank?  Theres the bolt hole on the back of the seat behind where the tank sits.  Then I had to drill a hole and bolt the other end through the floor
#183 Hegnirst
Hegnirst
  • 3,496 posts
Posted 30 December 2013 - 03:36 PM
sorry 'on' the petrol tank LOL nope never had one just secured by the petrol cap :P
will it be the same on my 1972? and do you have a picture from the inside where the bolt is?
thanks matey!
#184 Andy!
Andy!
  • 481 posts
  • Local Club: N/A
Posted 30 December 2013 - 05:01 PM
So regarding the fuel tanks, what happens with the honda fuel pump? i heard that you needed an MPI tank? I'm trying to wrap my head around how the float in the tank could work with the honda dials, as this build is very close to how im imagining attacking stuff! (keeping the honda clocks, moving the tank filler neck etc)
#185 Hegnirst
Hegnirst
  • 3,496 posts
Posted 30 December 2013 - 06:11 PM
yea mpi tank dude, this is one of them, just waiting on the pump through the post :)
im not too sure how that work either dude lol but im assuming that the wires on the tank just connect to where the honda wires would :P i think anyway lol
#186 Hegnirst
Hegnirst
  • 3,496 posts
Posted 01 January 2014 - 07:26 PM
well guys, just a small update.
Having the petrol tank finished, i decided to test fit it and see where the filler neck sat.
got the petrol tank out no problem as i do not have a tank strap LOL and i never had one LOL
there was even a fresh nut and bolt for the top mount of the strap. which is so weird because as ive said ive never had one over 3 years or whatever
anyway, the old one is now sale so PM if you are in need of one :) perfect working order and no rust at all :)
here it is test fitted, as you can see, its about 3 inches away from the boot which couldnt be better :D
excuse the messy boot, i will be painting it all black and the inlet needs to be stripped onto the skunk then ebay it goes lol small box of stuff to clean:
as well as painting the spacer plate for the passenger side underneath the subframe and im going to paint the brakes as well  just for good messure lol oo and something else which ive fogotten lol
#187 Hegnirst
Hegnirst
  • 3,496 posts
Posted 01 January 2014 - 07:35 PM
so i put the engine and subframe back in today, a little thing that i kind of what some one to show me what theres look like lol only because i want to make sure that i don have any problems lining up the drive shafts when it comes to it
this is where i think it needs to sit, this is the right one from the front as you can see there is no bolt in it. basically the hole of the rubber mount sits about the mount holes on the subframe. so really dont know what to do about it. because even if i stretch the rubber into place to line up with the holes the metal part of the engine mount will just sit on the frame and ide obviously just get vibrations from it all throughout the car. :/
and this is the left one, the socket was to just space it out to where i thought it should be when i was test fitting the manifold for the bulkhead.
#188 Hegnirst
Hegnirst
  • 3,496 posts
Posted 01 January 2014 - 07:47 PM
so i test fit the manifold with the engine is situ and i pretty happy with it ide say :)
I've gotta take about about another inch out of the passenger side of the manifold or so to get it to fit well the other side is perfect :) ignore the random paint on the wiper motor as it will be actually painted soon enough lol
so heres how it fits
so pretty good ide say for a test fit :)
the actual paint has made a huge reflection of how im now looking at this project i think :)
as im no longer working on a horrible dirty engine bay lol ive left all the bits that are going to welded or the like bare
so i think it looks pretty good now :D
so quite happy with that.
next is to fit steering rack and petrol pump and the actual tank in the car for good (when i get the rack mounts and honda petrol pump that Kieran has sent me)
which then is getting a box fabricated and welded in and then is just down to fitting the subframe and engine for good  hopefully then we can get some good progress on this thing :)
#189 Hegnirst
Hegnirst
  • 3,496 posts
Posted 01 January 2014 - 07:48 PM
here the petrol tank that i took out as well, PM if your interested :)
#190 Hegnirst
Hegnirst
  • 3,496 posts
Posted 04 January 2014 - 09:57 PM
a slight update, i think im going to change the 2 mini stalks to just the 1 honda lights and indicator stalk. Im going to put the ignition barrel in the dashboard unless for a legal reason i cannot. :)
ive started tangling through the wiring, this is box of looms :D oh how mighty how it is :D
this is the stalks of the honda which i think i have the plugs for, i think :P
as you can see i just need to simply unscrew the stalk i don't want :)
for the other switches i have these to sort through to see if there any use :)
375698_10150379486654362_1842483898_n.jp
still no idea what it does? a guess would be its for to normally bypass a couple of things like abs or whatever for certain purposes? i dunno!
Also, is this fubarb?
as i have a new steering rack and would like it too work :P
#191 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 04 January 2014 - 10:02 PM
Won't you need the ignition barrel for the steering lock for an MOT? Coming on nicely, looks good!
#192 Hegnirst
Hegnirst
  • 3,496 posts
Posted 04 January 2014 - 10:10 PM
well my clubbie is 72 so i dont know, but for example a mk1 mini does not have steering lock :P
#193 IainStallard
IainStallard
  • 1,114 posts
Posted 04 January 2014 - 10:21 PM
If it had one as standard, I think it's got to keep one :/
#194 Andy!
Andy!
  • 481 posts
  • Local Club: N/A
Posted 04 January 2014 - 10:37 PM
Why are you using the honda stalks? Surely using the mini electrics for the lights and stuff would be simpler, the only thing i can think of what may be a problem with that though is linking the mini stalks up to the honda dials (for indicators,hazards and full beam...) hmm...
#195 Hegnirst
Hegnirst
  • 3,496 posts
Posted 05 January 2014 - 10:17 PM
hmmm i will investigate further :)
