Headlight/indicator
4 replies to this topic
#1 700615948
700615948
    Starting My Mini Up
  • 3 posts
Posted 03 November 2013 - 09:18 AM
Hi all,
I'm looking for help please.
I need 2x headlight lamps which have incorporated inside the sealed beam the indicator lamps which are preferably LED type lamps.
This is required for a 1991 standard mini!
I've seen on ebay sealed beans for my car with a halo ring incorporated or even half halo ring on the bottom half. However I need both headlight and indicator within one unit.
Any help or contacts would be most appreciated
Thanks Gary
#2 mab01uk
mab01uk
  • 12,413 posts
Posted 03 November 2013 - 11:10 AM
Is this any good for what you want to do?
7inchdrlledheadlight-Copy_zpsc91fbd61.jp
NEW 7" Round LED DRL style Headlights for Austin Mini Morris van cooper/s pickup
http://www.ebay.co.u...=item27d1c272ca
Also some very expensive full LED classic Mini headlights here from same seller:
http://www.ebay.co.u...=p2047675.l2557
Quote:
With a low beam output of 28W and 24W on low and high beam respectively these are powerful headlights.
If wired up so that main beam and dipped beam are on simultaneously for main beam this will give a 52W led headlight !
These come with a 2 year guarantee against LED failure.
These are fully E Marked approved for road use and are RHD ( Right Hand Driver ) so suitable for UK and Japan use etc.
These lights are fully waterproof - as you don't need to change the bulbs they are fully sealed
With MOT regulations clamping down on HID type lighting these are by far the best legal headlamp technology on the market today.
These lamps have the following functions ...
1) Side light - there is an inner "angel eye" powered by 12 LED's
2) Dipped Beam - this is your normal driving headlight and has the "kick up" on the left side to illuminate the pavement. This is powered by the central LED's behind the glass lens and the outer 2 left and outer 2 right LED's
3) Main Beam - this is the full beam used at night when the there is no oncoming traffic. This is powered by the outer ring top 4 and bottom 4 LED's
Also not much help to you I know but the forthcoming new Mk3 F56 MINI has halo ring headlights......the top half of halo ring is for LED DRL (Daytime Running Lights) while bottom half is for indicator. :mrcool:
Edited by mab01uk, 03 November 2013 - 11:55 AM.
#3 700615948
700615948
    Starting My Mini Up
  • 3 posts
Posted 03 November 2013 - 05:40 PM
I think these are the ones I spoke about, the bottom 12 LED look like they are indicators but looking at the read up it would appear they are side lights.
I will ring the company up tomorrow.
Thanks for the quick response
Gary
#4 mab01uk
mab01uk
  • 12,413 posts
Posted 03 November 2013 - 07:17 PM
Perhaps you could wire the bottom 12 leds 'smile' as indicators (if they are amber/orange or can be replaced with amber coloured leds) and use the original Mini indicators with clear lens as a pair of seperate side lights?
If you can open the headlight body up there are quite a few MINI enthusiasts who can offer advice and swap existing surface mount leds for different colours. (see link below)
MINI dash light colour change:
http://www.totalmini...our-change.html
Edited by mab01uk, 03 November 2013 - 07:26 PM.
#5 700615948
700615948
    Starting My Mini Up
  • 3 posts
Posted 04 November 2013 - 06:17 AM
Many thanks
