Waterproofing Dizzy.
11 replies to this topic
#1 nollyd
nollyd
  • 663 posts
Posted 02 November 2013 - 05:03 PM
Hi all.had prob with my little 998 auto yesterday in rain.fitted cover from rocker cover down front of engine.will this solve the prob of misfiring when wet or is there a way to waterproof the dizzy.heard of the plastic bag with elastic band method but just wondered if theres a better way.cheers guys.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 02 November 2013 - 05:12 PM
The cover should solve it, but if it doesn't you can cut the finger tips off of a marigold glove and cable tie it on.
#3 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 02 November 2013 - 05:15 PM
LOL ive actually done this myself!
#4 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 02 November 2013 - 05:19 PM
Or... You could fix the problem once and for all and fit an electronic distributor, rather than bodging :-)
#5 alex-95
alex-95
  • 6,025 posts
Posted 02 November 2013 - 05:22 PM
you could do but a marigold is much cheaper and does the job ;D
it's not really a bodge         ...          an improvement.
#6 HarrysMini
HarrysMini
  • 3,352 posts
Posted 02 November 2013 - 05:29 PM
That's true, but it only does the job until it breaks/falls off.
I personally like to fix/prevent it properly, but you may as well wait until it needs new points or something rather than binning a perfectly working dizzy :-)
#7 alex-95
alex-95
  • 6,025 posts
Posted 02 November 2013 - 05:35 PM
you don't need a whole new dizzy, you can buy the part from accuspark or make your own from the maplin electronic kit for £10 like we did for the Ritz.
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 02 November 2013 - 05:50 PM
electronic ignition isn't a cure anyway.
damp problems are normally caused by tracking through the dirt on the cap and leads...you've still got a spark going up the leads
so best cure is keep it dry and clean.
#9 HarrysMini
HarrysMini
  • 3,352 posts
Posted 02 November 2013 - 06:00 PM
Surely it is to some extent as there are no points and therefore less electrical contacts to get wet.
Obviously, it doesn't prevent water getting on the leads/cap etc. so they still need to be maintained. But it's safe to say that most damp problems in ignition are caused by the points.
#10 lrostoke
lrostoke
  • 6,923 posts
Posted 02 November 2013 - 06:04 PM
I have exactly same damp problems with points and electronic.
open bonnet when its damp and dark its like a firework display, sparks everywhere.
I use a plastic bin bag, folded into a square, push down past the dizzy and up covering the leads, not pretty but works
#11 Ethel
  • 25,919 posts
Posted 02 November 2013 - 06:08 PM
Good condition leads, and don't overlook the low tension side. Use insulated connectors with a smear of Vaseline on the contacts, and arrange the wires so water drains away from the terminals. Ill fitting gloves etc. can be as good at keeping moisture trapped in.
#12 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 02 November 2013 - 07:23 PM
As above the leads need to be in good condition to prevent tracking and is one thing often overlooked, if your leads are over 5yrs old and a everyday driver replace them. coil turrets need to be kept spotless free from dirt. and also the outside of the disrributor cap.
