Play In Front Wheel
20 replies to this topic
#16 robminibcy
robminibcy
  • 1,516 posts
Posted 13 November 2013 - 11:48 PM
New wheel bearing cured the 12 and 6 o'clock play. A new steering rack cured the 9 and 3 o'clock play. Strange as the wheel bearing was new and had done about 1 mile?
Paul.
not really! There have been loads if threads related to the quality or indeed lack of when it comes to new parts especially non genuine. You might well have been one of the many unlucky ones who got a duff part
#17 PaulColeman
PaulColeman
  • 712 posts
Posted 14 November 2013 - 07:44 PM
Oh well, never mind, for the sake of about £15 I'm not going to worry about it :)
Paul.
#18 ings
ings
  • 201 posts
Posted 01 October 2019 - 11:25 AM
I had this week also play in 9 3 direction. Steering arm bolt was lose, just a half turn and the play was gone...
#19 DeadSquare
DeadSquare
  • 3,093 posts
Posted 01 October 2019 - 02:26 PM
There should be two annular dowels between the steering arm and the hub, through which, your aformentioned bolt passes.
If you have had the play that you mention, those dowels should be checked for wear and at least rotated through 90 degrees, if not replaced.
I once saw very little prolonged movement, produce so much wear that for safety, both dowels, the arm and the hub had to be replaced.
#20 Spider
  • 14,849 posts
Posted 01 October 2019 - 07:16 PM
Given the bolts have (or normally have) a Locktab, I find they stretch and that's how these come loose. Then after a while they break.
I'd suggest replacing these bolts with new.
#21 tamlamotown123
tamlamotown123
  • 95 posts
Posted 03 October 2019 - 08:36 AM
Hi suggest you check that the setscrew holding the steering arm to wheel hub is tight, it is the one with the locking plate.
