Rear Wheels Toe Inwards
20 replies to this topic
#16 Icey
Icey
  • 1,551 posts
Posted 24 August 2015 - 12:16 PM
I was taught back in the '60's and I use long straight edges, a tape measure, a steel rule and some beer-bottle crates. All a bit basic, but done carefully it works well.
I was doing this at the weekend to get the geometry roughly right. Laser line, set-square, steel rule and a couple of spirit levels. Really quite simple to get toe and camber in the ball-park, castor is proving a little more but not insurmountable.
#17 Cooperman
  • 23,278 posts
Posted 24 August 2015 - 12:48 PM
We used to set all our cars up like that as it was the best available back then. If you do it correctly and accurately it is quite alright.
I do agree that measuring castor is much more difficult.
#18 Spider
  • 14,849 posts
Posted 24 August 2015 - 08:47 PM
Usually a set of graduated turntables are used to measure caster, then from the numbers read off the camber gauge, the castor is calculated. I found that too slow and tedious so I have made a jig that fits over the top and bottom ball joint nuts, so now it's a direct reading, but there is no caster on the rear of these cars.
I did the measurements with strings as you do Cooperman for many many years, very accurate method if you take a little time and care. I made up the lazer as now I can see it from under the car as I adjust, so now there's no need to turn a bit, measure, turn a bit more, measure,,, just adjust while looking, lock off and lets go!  Kinda like reading of one of them modern digital verniers - in a way. It's fairly simple and most of the bits I bought at the hardware (mostly square section aluminium), once it was done, I calibrated it on the bench with a 1 metre ruler.
#19 ado15mk3
ado15mk3
  • 12 posts
Posted 24 August 2015 - 11:36 PM
will measure when i figure how to.
is it like this?:
1/ install concrete bricks - one near rear wheel and one near front
2/ run nylon line between bricks and tie off at each end
3/ measure distance between centres of both wheels to the line respectively and adjust line until both measure the same
4/ measure front and rear edges of rear tyre - difference here is the toe
but i want to know do they generally look toe in by that much as in pic above?
can anyone show a pic of how a correctly set up rear wheel looks from above?
thanks guys
#20 nicklouse
  • 18,583 posts
Posted 24 August 2015 - 11:47 PM
As said looks fine.
Or does not look wrong.
#21 ado15mk3
ado15mk3
  • 12 posts
Posted 31 August 2015 - 11:58 PM
hope this can help someone else.
this is my 11 yr old project and haven't seen the wheels on the car in a long time hence my confusion.
today I remembered that i had arches in storage so see before and after pics below.
it still looks a little off but much better than I first thought.
thanks for the replies.
W/O ARCH
Attached File  DSC_3147_2.jpg   33.86K   14 downloads
WITH ARCH
Attached File  DSC_3150_2.jpg   27.32K   10 downloads
    Bing (1)
