My rear wheel on my mini are toeing in quite alot?
any ideas if this i correct and how much pics would be great
ill upload mine when i get in
Posted 02 November 2013 - 01:31 PM
Posted 02 November 2013 - 06:57 PM
Factory setting is for a very small amount of toe-in for the rear wheels (3mm toe-in, unladen).
If the amount toe-in is noticeable then it's probably too much. Also needs to be the same on both sides...
Posted 02 November 2013 - 10:03 PM
Posted 02 November 2013 - 10:15 PM
The shape of the rear of the body of a mini makes it look worse than it is. By that I mean the rear is narrower than the middle so the body line is going out, when viewed from the rear, and the wheels/tyres are going in. But by all means get it checked to make sure both rears are pointing the correct amount in the right direction.
Posted 02 November 2013 - 10:20 PM
First of all measure it accurately.
If it is toeing-in by between 1 mm and 3 mm it will be fine.
Adjustment is by filing the hole in the rear radius arm pin locating bracket towards the front the increase toe-in and then welding a large washer onto the bracket to keep the setting, or fitting shims between the rad arm brackets and the sub0frame to reduce toe-in. Mini Spares sell the shims.
Make sure, when doing this, that the front and rear is aligned so that the car doesn't 'crab' along the road.
Posted 03 November 2013 - 09:19 AM
Optical illusion caused by the rear aches tapering in toward the rear of the car...
Measure it.
Posted 03 November 2013 - 09:22 AM
whats the best way to measure??
front of the wheel compared to the rear of the wheel?
Posted 03 November 2013 - 10:03 AM
Posted 24 August 2015 - 01:53 AM
is that how the rear tyre is supposed to look?
both my rear wheels look exactly like that and i thought something was wrong...
Posted 24 August 2015 - 09:46 AM
If in any doubt measure it.
Is it me, but are many people unwilling to measure things. Engineering is about accurate measurement.
Posted 24 August 2015 - 10:41 AM
Why measure when you can guess or ask what your mate recons?
Posted 24 August 2015 - 10:45 AM
Posted 24 August 2015 - 11:11 AM
yep it is dead. i will give the OP a tenner for the pile of scrap.
However, when I check and set rear toe, i have my own laser measurer, Rather than measure and set wheel to wheel, it measures back to a centre line, I set each wheel to that, then check wheel to wheel.
That way it doesn't crab. Not a good look to have one side at zero and the other at 1/8",,,,,
Posted 24 August 2015 - 11:31 AM
I was taught back in the '60's and I use long straight edges, a tape measure, a steel rule and some beer-bottle crates. All a bit basic, but done carefully it works well.
