Diagnostic Plug Location
9 replies to this topic
#1 smudger"s"works
smudger"s"works
  • 86 posts
  • Local Club: none yet but a member of BMC
Posted 31 October 2013 - 10:43 PM
Hello everyone,
I cant seem to locate my diagnostic plug anywhere, where is it normally located?
I have a 94 Spi cooper (John Cooper conversion) looks unmodified
I have located the alarm one (green) near the brake servo but having dramas locating the white one.
Any help would be much appreciated.
Smudge
#2 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 31 October 2013 - 10:55 PM
i didnt think they had them but ive just googled it and read on another forum it should be to the left of the steering wheel underneath where all the wires are.
#3 smudger"s"works
smudger"s"works
  • 86 posts
Posted 31 October 2013 - 10:56 PM
I googled and couldnt come up with anything, Well thankyou very much made my night cheers
#4 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 31 October 2013 - 11:03 PM
http://www.minifinit...t=20317&start=0
thats the link that i got it from.
or you could click this: http://lmgtfy.com/?q...ug classic mini
#5 smudger"s"works
smudger"s"works
  • 86 posts
Posted 31 October 2013 - 11:59 PM
That is the mpi one, I've serched on here and people say its next to the green (alarm) one. So my next question is - does the white plug come out the main loom and is it possible its hidden behind the air cleaner.
#6 Guest_minidizzy_*
Guest_minidizzy_*
  • Guests
Posted 01 November 2013 - 12:48 AM
Looking at the workshop manual (AKM 7169) the diagnostic connector for an SPi is under the bonnet on the bulkhead, left hand side just to right of the relay module.
#7 smudger"s"works
smudger"s"works
  • 86 posts
Posted 01 November 2013 - 07:56 AM
Ok thanks ill have a look later.
#8 FlyingScot
FlyingScot
  • 2,664 posts
Posted 01 November 2013 - 10:35 AM
It should have a black cover on it to prevent moisture and dirt ingress, so you might not see much of the white AMP connector. Have a feel around at the brake servo, it's sometimes tucked away (which means it hasn't be plugged into diagnostics for a while possibly)
FS
#9 humph
humph
    How bad can it Be?
  • 1,095 posts
Posted 01 November 2013 - 02:36 PM
FS
This. Mine is between the air filter housing and the brake servo.  As you say it's white, but as mentioned has a black rubber condom type cover on it
#10 smudger"s"works
smudger"s"works
  • 86 posts
Posted 01 November 2013 - 02:50 PM
Found it guys cheers for the help. It was hidden with the relay module wires cheers again
Smudge
