sealant / blu tack stuff
Posted 21 May 2006 - 11:15 AM
Posted 21 May 2006 - 11:32 AM
anyone know where i can get some sealant stuff from? (the stuff they use on the door catch, window winder cover, etc. it like blu tack but stickier!) or has anyone got any alternatives?
Dum-Dum?
I Hope that tarpaulin is keeping you dry!
Posted 21 May 2006 - 04:14 PM
I'd use silicone sealant, available from any hardware shops... better off from screwfix though as it works out loads cheaper, you can use it as a flexible adhesive and a sealant so its quite versitile.
Posted 21 May 2006 - 04:58 PM
Posted 21 May 2006 - 06:46 PM
It's similar to the cauling strip that modern windscreens are held in with. If you talk to your local windcreens place, they might let you have a little bit of offcut......
On the same subject of sealers, where can i get hold of the black stuff that seals the windows? Windscreen and rear window
The windows are held in in a rubber extrusion. you mean them, or the insert piece that "wedges" the seal closed? Either way, the minishops do them, plus most kit car places and woolies trim.
Posted 21 May 2006 - 06:50 PM
Ive just read what I posted and it looks like im talking about the rubber seal lol
What I mean is, Ive fitted all my windows in place and the silver insert, but they still leak! a lot!! actually, and i just need the sealer.
Posted 21 May 2006 - 06:53 PM
Posted 21 May 2006 - 07:10 PM
We use neoprene double sided tape to hold the glass into some frames. Its about 8mm by 3 and its incredibly sticky. I have used it in all sorts of situations on all sorts of cars (including on mini window mechs'). Its so cheap too, that if you go begging at your local window manufacturer, the lads in the factory might bung you a couple of metres for nowt (i know i would)
Al
Posted 21 May 2006 - 07:16 PM
How far is the postal service from you?couple of metres for nowt (i know i would)
Only kidding, So this tape goes into the rubber like channel?
Posted 21 May 2006 - 08:15 PM
Posted 21 May 2006 - 08:27 PM
It is not silicone - it doesn't set - and seals even better. Without it, even if you have new rubbers and chrome insert your windows will leak
Posted 21 May 2006 - 08:43 PM
Posted 21 May 2006 - 09:43 PM
But christ! I went round a right hand turn and loads of water from the dashboard area washed over my radio
I havent had time to see if it works :'( hope it does, thanks for the info for where to get the stuff
Posted 22 May 2006 - 07:25 PM
Maryquant, the stuff you want is called arbomast
Pop into your local windscreen company and speak to the fitters they should let you have some of each for a couple of quid.
Posted 23 May 2006 - 03:11 PM
Silicone particles become airbourne very easily, once on your car, are hard to remove.. you cant see them.. and make paint jobs a nightmare.
