Sound Deadening Vs Straight Cut Gears
14 replies to this topic
#1 Kt1966
Kt1966
  • 232 posts
Posted 30 October 2013 - 10:18 PM
About to send my car in for a paint and trim and wondering what people's views are on sound deadening.
I have a great 1100 Special which Oltonlad did a brilliant job with, but with straight cut gears it is, as you'd imagine pretty loud (my wife's not so keen, and I'd like to be able to use it on the motorway....)
What I am trying to work out is how effective sound deadening would be -does it work, is it worth doing, best material, are there any considerations with bits of trim fit etc etc.
Appreciate any views out there.....
Edited by Kt1966, 30 October 2013 - 11:42 PM.
#2 MichaelH
MichaelH
  • 41 posts
Posted 31 October 2013 - 09:00 AM
Hi,
I can only tell you: Go for it! My current Mini is not having any sound insulation at all, it was meant to be as light as possible when I've finished restoring it but meanwhile, I believe it is way too loud inside. Can't bear it any more :-(
Sound deadening helps a lot if done properly. A friends's Mini van was so well done that you could have an easy conversation even at 90mph - despite RC40.
I can't tell any brand names (and I possibly use the wrong technical terms in some places, forgive my lacks in english language...) but you need to do two things:
- Adding stick-on damping stuff like e.g. dynamat which keeps the shell itself from vibrating.
- Adding foam/felt/whatever similar material mats that absorb the noise itself.
The damping material possibly is already present on your Mini (as it came as std. unless very early Minis) unless it has been removed in the past.
I prefer to cover the firewall with foam from both sides (where the engine located side needs different material of course), the complete floor, wheelhouses from the inside and definitely the roof (which usually is already equipped unless removed)
This will help a lot to reduce noise in the inside.
HTH
Michael
#3 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 31 October 2013 - 09:06 AM
Sound deadening won't help.
All it does is reduce vibrations and makes more of a Golf sound when you shut doors, because all it is actually doing is making the panel heavier.
If you want to keep noise out, you need sound proofing. Lots of that applied especially on the bulkhead and under the bonnet will keep the noise out.
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 31 October 2013 - 09:10 AM
The whine from straight cut drops will be VERY hard to hide. You would need so much deadening material,that you would barely be able to fit in the car! I have only been in a car with them on a few occasions and its painful after a few miles. To my mind it takes all the pleasure out of the driving experience. For racing there is a positive benefit (and you are wearing a crash helmet) but they aren't good on the road.
#5 Midas Mk1
Midas Mk1
  • 5,777 posts
  • Local Club: S.U.N.M.C
Posted 31 October 2013 - 09:35 AM
Helical Gears. Followed a car with sc drops on l2b and it was annoying me, and my car aint quiet!
Edited by Midas Mk1, 31 October 2013 - 09:36 AM.
#6 Lucas1988
Lucas1988
  • 408 posts
  • Local Club: Frome Mini Club
Posted 31 October 2013 - 11:37 AM
Whats the difference?
#7 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 31 October 2013 - 11:40 AM
Straight cut gears transfer power more efficiency as there is no side thrust on the gears, however this means they whine which is deafening.
#8 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 31 October 2013 - 11:54 AM
Have you any reccomendations for sound proofing material and or suppliers?
#9 ejs-1995
ejs-1995
  • 108 posts
Posted 31 October 2013 - 01:12 PM
I've heard good things from dynamat although I don't know if it would be suitable for yourself.
A friend of mine had s/c in a mini and the noise was unbearable! I used to hate going in his car...
#10 TehMarchant
TehMarchant
  • 628 posts
Posted 31 October 2013 - 01:15 PM
Silent coat is the same as dynamat but is cheaper.
#11 freshairmini
freshairmini
  • 1,718 posts
Posted 31 October 2013 - 02:26 PM
http://www.deadening.co.uk/
Above shop has it all or someone like http://www.caraudiodirect.co.uk/ has this kind of stuff.
The best sound deadening solution is as follows:
A deadening material to absorb vibrations, something like silent coat or dynamat or similar.
An isolation material like carpet underlay. Closed cell foam is used allot with pro audio installs.
Then a heavy blocking material like a mass loaded vinyl, this will actually be doing the sound blocking and isolated from the deadening/bodywork by the carpet underlay or better closed cell foam.
Lots of info on the TalkAudio forum on this subject but how much it will help with SC gears, I don't know, its the kind of thing that's is not really done on minis as a lot of people would say don't bother (even though I would imagine not many people have tried...).
It's also not cheap to do this properly but when done well it can work very, very well. I would say if you got the cash free to experiment (read: throw away lol) then do it, I for one would be very interested in the results!
Edited by freshairmini, 31 October 2013 - 02:27 PM.
#12 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 31 October 2013 - 04:07 PM
depends what you use the car for. ok in mine, without any sound proofing
that's with a sc gearset too.
video there on a quiet drive lol
its just a toy so ok, daily covering many many miles it could get tedious
#13 Kt1966
Kt1966
  • 232 posts
Posted 31 October 2013 - 04:33 PM
Thanks everyone for the thoughts - really appreciate it.
I guess it's where the compromise is - on either the performance (which is great, and as SC gears go I think it's been set up reaslly well), but the price is noise. It's not a day to day car which helps of course, and the hassle and cost of changing to standard hears is a big factor too. The overall consensus seems to be it's not worth trying to mask the noise too much ??
Having just bought it, I could really do without more expense on engine/gearbox out etc etc
One of those toss a coin moments maybe ?
#14 Ethel
  • 25,922 posts
Posted 31 October 2013 - 05:04 PM
Christmas Prezzie?
Seriously, I'd just have a go with any old carpet underlay you can lay your hands on. If it has any effect you'll know if it's worth spending money to improve it.
#15 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 31 October 2013 - 10:46 PM
Not needed. When it sounds like that, who needs a radio??
