Oil Or Gas Shocks For Comfort Ride ?
11 replies to this topic
#1 psoutzis
psoutzis
  • 278 posts
Posted 26 October 2013 - 07:48 AM
Hey i have an Austin mini 998 1979, with standard cones on front and back.My result is a comfortable ride I will buy the soft coil-springs from huddersfield mini spares, and i am not sure if i have to change the dumbers too, i found Bilstein Gas shock absorbers, would that be good ? or oil dumbers would be a better choice for a soft ride?
#2 rally515
rally515
  • 3,848 posts
Posted 26 October 2013 - 08:29 AM
Alot of love for the GAZ company shockers these days, not many tailor to comfort on here though :lol:
Oh and its Dampers not dumpers ;D  :kiss:
Edited by rally515, 26 October 2013 - 08:29 AM.
#3 psoutzis
psoutzis
  • 278 posts
Posted 26 October 2013 - 08:48 AM
hehe so will go for Oil Dampers ?
#4 psoutzis
psoutzis
  • 278 posts
Posted 26 October 2013 - 08:50 AM
#5 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 26 October 2013 - 09:05 AM
and its shocks not shockers!!!!!!
#6 rally515
rally515
  • 3,848 posts
Posted 26 October 2013 - 09:23 AM
>_<  :(
#7 yeti21586
yeti21586
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 26 October 2013 - 09:29 AM
:bah:  :teehee:  :whistling:  :turtle:  :techsupport:  :mrcool:
#8 freshairmini
freshairmini
  • 1,718 posts
Posted 26 October 2013 - 12:30 PM
Ha, isn't it technically dampers, not shocks or shockers?! :D
#9 rally515
rally515
  • 3,848 posts
Posted 26 October 2013 - 12:41 PM
"Shock absorber (British or technical use: damper), a mechanical device designed to dissipate kinetic energy"
So i guess us brit's should say Damper :gimme:
#10 Ethel
  • 25,922 posts
Posted 26 October 2013 - 01:25 PM
All shompers (compromise name) contain oil. Gas dampers just  have an inert gas sealed in that performs more consistently than air -  they need something squishablee to allow for the space taken up by the pushrod when they are compressed.
It has little to do with the ride, that's down to the valving & oil viscosity. If you have a harsh ride replacing the suspension rubber cones is a more likely remedy.
#11 Cooperman
  • 23,278 posts
Posted 26 October 2013 - 04:28 PM
Comfortable Mini is a real oxymoron. If you want comfort you don't buy a Mini.
Minis are harsh, noisy unreliable (compared with modern cars) but FUN ;D .
Don't waste your money on coil springs and all the work in fitting them. Just get a good set of GAZ dampers and set the stiffness to whatever suits you. You can't beat the original design with the rising rate rubber springs.
#12 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 26 October 2013 - 04:36 PM
standard rubber cones and oil normal non uprated oil shocks  with all the other bushes etc in good order the car will be smooth and drive lovely
