Allspeed Subframe Problems Anyone?
7 replies to this topic
#1 Austinminimark
Austinminimark
  • 260 posts
  • Local Club: redditch
Posted 25 October 2013 - 09:54 PM
Hi I have just ordered a allspeed subframe just wondering if any of you guys have encountered any problems?
#2 KieranB
KieranB
  • 360 posts
  • Local Club: S.U.N.M.C
Posted 26 October 2013 - 05:04 PM
As of yet, no. The only thing I would say is they are difficult to use if you are trying to get a standard length front end on as the radiator gets in the way, some modifications need doing to the front bars to make it fit. Apart from that its easy to install, easy to mount the engine to and is a quality piece of kit.
Best of luck
Kieran
#3 Austinminimark
Austinminimark
  • 260 posts
Posted 26 October 2013 - 09:23 PM
Okay thanks well I'm attempting a b16 turbo build but mybe using a custom rad. So should be a problem .:)
#4 babyrich82
babyrich82
  • 133 posts
Posted 31 October 2013 - 02:10 AM
Hello
I have a very tight budget to complete my whole car, I was just wondering how much money from start to finish an Allspeed conversion will cost?
Anyone have any ideas?
Rich
#5 KieranB
KieranB
  • 360 posts
Posted 31 October 2013 - 08:16 AM
Hello
Rich
http://www.theminifo...2765-vtec-help/
#6 Hegnirst
Hegnirst
  • 3,496 posts
  • Local Club: Hilltop Minis
Posted 31 October 2013 - 01:55 PM
Hello
Rich
rang them today for mine,
you can use your top arms,
shocks,
hi lows
everything else:
Subframe / unpainted £650.00
Bottom arm tie bar set £285.00
Driveshafts 32t honda to 25t mini £330.00
HD outer cv joints to suit above £194.00
Alt bkt £68.00
Shipping UK £30.00 ( subject to postcode )
Net total £1557.00
Vat @20% £311.40
Total inc delivery and vat £1868.40
quoted from an email from him.
Hope this helps!
and no its not any cheaper if you collect! lol
#7 Austinminimark
Austinminimark
  • 260 posts
Posted 31 October 2013 - 06:56 PM
I reckon being reasonable you could spend 4 to 6 grand depending on what you planing on changing like for instance coilovers rollcage. Are you changing to a limited slip diff it all comes down to how much you pick the engine and running gear up for and what kind of car your building. A race spec mini for on the road or like standard interiror sleeper style. But it's still alot of money. I've only just ordered the subframe and I've got all the engine but I'm attempting to turbo charge it but until I get the subframe I don't know which way I'm going to set up the manifold to not have anything poking out of the front :/
#8 babyrich82
babyrich82
  • 133 posts
Posted 01 November 2013 - 12:15 AM
I have a separate budget for all the welding and respray works for the car etc.. I was just trying to gauge the total amount for the engine conversion really, I've seen some £500 lumps with ecu and gearbox on eBay (of all places), I would rebuild the engine myself (being an engineer), and then £2k (ish) for the kit, is there anything else I would require?
