Project Ruby - 1981 Hl
roundnose
229 replies to this topic
#121 Cookiez
Cookiez
  • 205 posts
Posted 28 January 2016 - 11:30 AM
Long time no update, so here goes.
Inner wing holes welded up & filled
A few items fitted to check its all Ok before it goes to paint
Changed a few more welded nuts to Stainless Clench nuts
We are changing the bonnet to use the MiniVation Gas Bonnet lift kit.
So we have done away with the bonnet stay & retaining clip
Next on to the doors
Trying to make these areas look a little better
Subframe Trial fit
This bit dont look right, sorted it tho.. :blink:
Front subframe
You can also see the slam panel holes all welded up too
So She is not ready for paint just yet. Getting there tho.
Edited by Cookiez, 26 September 2019 - 03:32 PM.
#122 Cookiez
Cookiez
  • 205 posts
Posted 25 February 2016 - 04:37 PM
Now that all the welding is done
I have put the carpet tiles back down in the garage
I cant be doing with kneeling on a cold floor
Holes drilled for pop out windows
Spot weld holes filled on front & rear valance
Removed paint from wing gutter ready for filling
Filled, waiting to rub down
Tidy the front sill area up
From this
To this
And the rear
To this
Above windscreen gutter area
I hate bodywork
Edited by Cookiez, 26 September 2019 - 03:43 PM.
#123 Cookiez
Cookiez
  • 205 posts
Posted 25 February 2016 - 04:40 PM
Whats the opinion on lead loading the wing to scuttle seams
Im not sure what to do with them, On Ruby I had them sealed with a PU Sealer, but they still cracked.
Ta
#124 James_eaton_thewholething
  • 1,063 posts
Posted 26 February 2016 - 02:05 PM
What PU sealer did you use last time ?
#125 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 26 February 2016 - 03:28 PM
Excellent work, what did you put down the bonnet/wing channel? looks like upol dolphin glaze?
#126 Cookiez
Cookiez
  • 205 posts
Posted 26 February 2016 - 05:53 PM
James, It was U-Pol tiger seal, I dont think it really was the PU sealer that split, Maybe it was just the paint on top.
Spot on Alex, Its U-Pol Dolphin Glaze
After speaking with a few people about running some lead in the seam area.
Ive been told, because I want it to run right to the bottom of the seam and not filling all the way to the top of the seam.
I will have to get a fair bit of heat into the pannels, this may lead to some distortion.
Im not prepared to let this happen, So I may just get everything nice and warm and let some Dolphin Glaze run right down to the bottom of the seam.
I want to try and retain the factory look by not filling it to the top.
#127 alex-95
alex-95
  • 6,025 posts
Posted 26 February 2016 - 06:12 PM
Cheers, Do you think it will be flexible enough for there? and down the wing scuttle join? I'm not sure whether to put some seam sealer in the bonnet gap as it's much more flexible.
#128 Cookiez
Cookiez
  • 205 posts
Posted 27 February 2016 - 11:18 AM
Alex.
Seam sealer is a bit more flexible, but I dont think you can get a good enough finish on it.
I have sealed the front bumper lip with a 3M product called "Drip Check"
The finish is not to bad on that, I went over it with a small brush with some thinners on, then wiped over with a rag with thinners on.
Its supposed to be for "older" cars seams.
here is the data sheet.
http://multimedia.3m...ealer-08531.pdf
From what ive been told the warmer you get the work area & product, the better it flows.
#129 Cookiez
Cookiez
  • 205 posts
Posted 30 March 2016 - 06:45 AM
Ive still not decided what to do on the wing to scuttle seam.
I think im going with a PU sealer, but not going to the top of the seam. Keep it as low as I can.
The bonnet on Ruby had split right on the tightest bit of the curve, When I looked at the same are on Ruby Two's bonnet,
it looks like it could well do the same, there seems to be a thinner edge to the bonnet.
I have made a reinforcing section that I have plug welded in
Edited by Cookiez, 26 September 2019 - 03:45 PM.
#130 Cookiez
Cookiez
  • 205 posts
Posted 31 March 2016 - 12:01 PM
Yay, look at this
Woking on Ruby Two with the garage door open
Removed all the paint & excess seam sealer from roof gutter area
Fill with dolphin glaze
Rub down & prime
Edited by Cookiez, 26 September 2019 - 03:46 PM.
#131 Cookiez
Cookiez
  • 205 posts
Posted 01 April 2016 - 09:24 AM
We have paint
Spray painted all the cavities with some black rattle cans with a long nozzle while turning on the spit to ensure good coverage
Then it was time to mask up for the Gravitex
Once this was applied we removed the masking and left it for a few days to the the solvent come out.
A bit of a tidy up, Ruby Two had a trip outside to get the dust blown off
Then back to masking up, again.
Mixing the paint
That looks better
Then more masking and on to the inside
Once dry it was even more masking and onto the Engine bay & Boot
Edited by Cookiez, 26 September 2019 - 03:57 PM.
#132 James_eaton_thewholething
  • 1,063 posts
Posted 01 April 2016 - 11:04 PM
Looking good. I'm starting to paint mine at the moment.
I have a question for you. What do you use to get the paint out of the tin and into the mixing cup. I'm currently using syringes but the rubber in them fails and then they break.
#133 Cookiez
Cookiez
  • 205 posts
Posted 02 April 2016 - 09:43 AM
Hi James
Thanks.
Good luck with yours.
I just tip the paint in the mixing pot
I keep a pannel wipe cloth near to wipe up any drips
I am using large mixing pots tho
#134 Cookiez
Cookiez
  • 205 posts
Posted 04 April 2016 - 03:09 PM
A few more bits painted
Time to get it booked in to get the rest of it painted now
Edited by Cookiez, 26 September 2019 - 03:59 PM.
#135 Cookiez
Cookiez
  • 205 posts
Posted 08 April 2016 - 10:56 AM
Side seam seal strip covers painted
Painted the seams before the covers get bonded on
The black clips are what came from Heritage
The silver ones are stainless ones from Mini Sport
Im sure the black ones wont hold the seam covers on very well, they seem to be missing the points that grip to the inside of the seam cover.
Ive decided Im going to have the insides of the doors, bonnet, boot, compainion bins and the A & B pillars repainted at the same time the outside is done, This will be base coat and lacquer,
Edited by Cookiez, 26 September 2019 - 04:00 PM.
