Project Ruby - 1981 Hl
roundnose
229 replies to this topic
#106 Cookiez
Cookiez
  • 205 posts
Posted 05 November 2015 - 03:37 PM
Inside floor pan all seam sealed
Behind Dashboard Area All Seam Sealed
Parcel shelf seat belt spreader plates
3mm Stainless plate
Fitted
Bonnet slam panel holes welded up
Cross member / Inner wing support holes welded up
Wing / A Panel support changed to a thicker one
Selection of stuff removed from the shell so far
Edited by Cookiez, 26 September 2019 - 03:21 PM.
#107 johnR
johnR
  • 2,296 posts
Posted 05 November 2015 - 07:57 PM
just read through your post - what a same about Ruby 1 after all that work - maybe a brighter colour next time!
Great to see your attention to detail - at least the experience of the first build and the shell to refer to must be useful - I'd have welded up a lot of the holes on my shell but by the time l'd stripped it all down I'd forgotten which ones I needed and which I didn't.
I'm surprised you're not having a permanent foglight - especially after being rear-ended before?
Keep up the good work,
JohnR
#108 James_eaton_thewholething
  • 1,063 posts
Posted 05 November 2015 - 10:23 PM
How come you have a A panel and wing support. Was it a standard thing or something you have added ?
#109 Cookiez
Cookiez
  • 205 posts
Posted 06 November 2015 - 08:59 AM
Hi John
Thanks for the comments about Ruby
Jack wants to have Ruby Two the same colours as Ruby,
I could do with something to make more noticeable, although I'm not sure Jack will be using her in the same way as he did before.
James
Id never seen a support fitted before, It was a friend who painted Ruby who told me to fit one.
This is the one that came on the new Heritage shell
Not really doing much
While I'd got the stainless plate out doing the seat belt mounts I made some to replace the standard ones
Edited by Cookiez, 26 September 2019 - 03:23 PM.
#110 James_eaton_thewholething
  • 1,063 posts
Posted 06 November 2015 - 11:09 AM
I wonder why they decided to do that. It would make sense possibly on the sports pack shell. Ah well atleast it's not coming apart at that seam.
#111 alchall
alchall
  • Just Joined
  • 604 posts
Posted 06 November 2015 - 12:01 PM
Don't think it's anything new, my Haynes mini restoration manual includes a reference to it and that's quite old, certainly pre-dates sports pack.
I fitted the small ones on mine but I did weld it on both sides whereas it looks like heritage only spot welded on the lip.
#112 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 November 2015 - 12:22 PM
i believe it is to stop the join from flexing
#113 James_eaton_thewholething
  • 1,063 posts
Posted 06 November 2015 - 02:49 PM
Fair enough. is it something they started doing on later cars ?
#114 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 November 2015 - 02:56 PM
I don't think so. Mine is 1984 and has them
#115 James_eaton_thewholething
  • 1,063 posts
Posted 06 November 2015 - 03:24 PM
Mine didn't have them it's a 1991
Edited by James_eaton_thewholething, 06 November 2015 - 03:26 PM.
#116 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 November 2015 - 03:56 PM
Perhaps someone had replaced the wings and/or A panels in the past and not replaced them?
#117 Cookiez
Cookiez
  • 205 posts
Posted 09 November 2015 - 11:43 AM
I was having a close look at the spot welds on the bottom of the flitch
All looked ok until I had a poke about
Removed the primer to reveal a split caused by spot welding yet again
More seam sealing, Will this ever end
One step forward & one back this weekend
I will have to redo the inside flitch areas after finding the crap spot welds above
Air vent blocking plates fitted, there were originally on Ruby, Feels nice bolting a few bits of her back on here.
Edited by Cookiez, 26 September 2019 - 03:24 PM.
#118 Cookiez
Cookiez
  • 205 posts
Posted 10 November 2015 - 01:46 PM
Stainless Clinch Nuts in Indicators & Headlamp Bowls
Routing the Petrol Pipe
This is the easy side, the newer floor pans have a channel through the front heel section
On the passenger side I want to use the larger strengthening section to keep the brake line out of contact with the floor
If I do this I run into a problem on the Drivers side heel section
I'm going to cut out this area and put in s channel section so as it keeps the brake line symmetrical to the petrol line
Edited by Cookiez, 26 September 2019 - 03:25 PM.
#119 Cookiez
Cookiez
  • 205 posts
Posted 17 November 2015 - 03:51 PM
Channel section cut and welded in
View from inside after a bit of primer
View from the underside
Now onto welding up the holes for the left hand drive wipers
Edited by Cookiez, 26 September 2019 - 03:26 PM.
#120 Dmini7
Dmini7
  • Validating
  • 35 posts
Posted 22 November 2015 - 09:42 AM
Awesome thread dude! Such a shame what happened I'm gutted for you! But I'm sure this one will be just as good if not better. Keep up the good work
