Project Ruby - 1981 Hl
roundnose
229 replies to this topic
#91 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 10 October 2015 - 05:37 PM
They are where the slinging brackets were attached to at the factory.
They are not needed after that so can be blocked up
#92 alchall
alchall
  • Just Joined
  • 604 posts
Posted 11 October 2015 - 10:18 PM
I'll be blocking these up too, along with all the drain holes as you've been busy doing, also I'll be cutting off the 4 slinging brackets in the corners as they seem to be dirt and water traps and also easily mistaken for jacking points.
I wouldn't be doing this if I was after a concourse original restoration but that's not what I'm doing so staving off future rot for as long as possible is the name of the game for me.
#93 Cookiez
Cookiez
  • 205 posts
Posted 12 October 2015 - 02:34 PM
Thanks Ben
Boot floor holes all done now
The less holes underneath the better in my view
I will have to drill two holes for petrol pipe & overflow / vent
Horrible heavy handed spot welds, this one has punctured the floor, Some of the spot welds have deformed the metal.
Leaving horrible ridges
Covering the Jacking point hole up.
Jack never uses the original Jack so for us serve no purpose.
Edited by Cookiez, 26 September 2019 - 03:16 PM.
#94 Cookiez
Cookiez
  • 205 posts
Posted 14 October 2015 - 07:44 AM
Boot floor Done
Exhaust cut out on valance filled in
Valance holes done
I was looking back through some old pictures of when I was repairing Ruby
It was this time of year, 4 years ago that I was welding up the holes in the boot floor
Hey Ho !!
Onwards we go
Now to start filling the holes in the main floor
Edited by Cookiez, 26 September 2019 - 03:17 PM.
#95 Cookiez
Cookiez
  • 205 posts
Posted 19 October 2015 - 02:40 PM
Main floor area holes all done
Left Hand steering hole blocked up
A few bits that I've removed
More bits to make Jack a key ring from
Question time again
Why did the floor pan change so much between Mk4 & Mk5
Are the deeper ridges used for anything?
Edited by Cookiez, 26 September 2019 - 03:18 PM.
#96 alchall
alchall
  • Just Joined
  • 604 posts
Posted 19 October 2015 - 03:02 PM
Looks clean without all the holes and brackets, are you intending to use p clips to hold the brake and fuel lines in place?
That deep wide ridge on the passenger side that cuts through the front floor pan is where the fuel lines run on the later cars if that's what you were asking about?
#97 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 19 October 2015 - 03:04 PM
Won't you need the left hand steering rack hole to access the grease point on the rack?
#98 Cookiez
Cookiez
  • 205 posts
Posted 19 October 2015 - 03:41 PM
Yea, Stainless "P" clips for the Brake & Fuel lines
I was hoping I could fit the ones from Ruby back on this one but it looks like I will remake them to fit the new floor.
Ben, I should have fitted a right angle nipple
I had blocked the hole up on the other shell too
Just to add a note
If anyone is interested to come and have a look at the shell or pop in for a chat, Coffee & Tea are always on offer
I'm only 5 mins from Junction 28 on the M1
Edited by Cookiez, 20 October 2015 - 06:42 AM.
#99 alchall
alchall
  • Just Joined
  • 604 posts
Posted 19 October 2015 - 04:42 PM
I'm thinking of doing this for the brake lines (fuel lines attach with plastic clips on the SPI so I'm going to stick with that for those), how do you fasten them? I'm thinking drill some holes in the floor and weld in small bolts then use stainless nuts to hold them in place?
#100 Rocket.
Rocket.
  • 1,441 posts
Posted 19 October 2015 - 05:30 PM
Must be nice to work on a Mini with no rust
Looks great
#101 Cookiez
Cookiez
  • 205 posts
Posted 19 October 2015 - 08:48 PM
Ben,
What grease point?
Rocket - Yes it is different. Although when drilling the spot welds out, I have missed that layer of rust to tell you that your half way through.
And trying to protect against the rust is another problem.
#102 1984mini25
1984mini25
  • 8,784 posts
Posted 19 October 2015 - 09:11 PM
It's not a grease point, either. If you remove the plastic Allen plug in the rack, you can then drop the shank of a 6mm into the steering rack to centre the rack and the steering.
Edited by 1984mini25, 19 October 2015 - 09:12 PM.
#103 Cookiez
Cookiez
  • 205 posts
Posted 20 October 2015 - 06:48 AM
I remember using that hole now to set the steering to the middle before we put the rack on
Questions again
Any ideas how to spray paint into the sill cavities ?
#104 alchall
alchall
  • Just Joined
  • 604 posts
Posted 20 October 2015 - 09:00 AM
Questions again
I'm using this...
http://www.frost.co....ray-nozzle.html
It's expensive but it does seem to seep into all the gaps in the seams as it will come through the other side even where it looks very tight, might be over kill though as you're certainly not going to have any lurking rust in any box sections, I was concerned for example about the A posts either side of the windscreen.
Alternatively this might work on any old rattle can....
http://www.bilthambe...injection-lance
#105 Cookiez
Cookiez
  • 205 posts
Posted 20 October 2015 - 11:01 AM
I used rattle cans and a long nozzle last time with Ruby
I put 2 cans of primer & 2 cans of gloss black in each sill while rotating it at different angles and letting the paint settle before rotating again
I also did every other hole I could find
I just wondered if there were any better way, I'm not 100% sure the rattle can has enough pressure to blast the paint into every bit
Edited by Cookiez, 26 September 2019 - 03:19 PM.
