Stunning! Gotta be concourse! Ace work!
#31
Posted 11 January 2014 - 11:14 PM
#32
Posted 11 January 2014 - 11:40 PM
Attention to detail takes time and I can see a lot of time has gone into this build. Good job guys
Pete
#33
Posted 12 January 2014 - 05:12 PM
Thanks for all the comments guys
I never started out trying to get the Mini to this level
Attention to detail soon grabs you and you strive to do the best you can.
I think my standards have changed as the build has gone on..
#34
Posted 21 January 2014 - 12:04 AM
Any updates?
#35
Posted 21 January 2014 - 10:24 AM
Only a few little updates
Carb was stripped
A mate took it to his Kart workshop and put it in his ultrasonic cleaner
This removed all the gunk that had built up over the years
I ground most of the sharp edges off the inlet / outlet manifold left by casting
Then the manifold & carb were put back on the Mini
One of the other cars I have needed some work for MOT
Ruby had to come out of the garage onto the drive for a while
She only came out because it wasn't raining LOL
Once back in it was on with getting the front half of the wiring loom in place
All wrapped with a fabric tape
Earth lugs all redone & soldered on
Jack re did all of the bullet connectors where it connects to the rear part of the loom
But to be honest we were not that happy with them
So we chopped them off & soldered them in place
Edited by Cookiez, 26 September 2019 - 11:49 AM.
#36
Posted 21 January 2014 - 10:31 AM
Id got a few little bits to paint the other day
Jack asked if I could spray his bike frame at the same time
Obviously he wanted it the same colour as Ruby LOL
He spent the day prepping the bike frame
A quick blast of etch primer then some wet on wet action with the top coat & here you go
Colour coordinated Mini & BMX
Kids eh, things you do for em
Not really a Mini update, but I hope it gives you an idea of what I have to put up with..
Edited by Cookiez, 03 October 2019 - 09:07 AM.
#37
Posted 23 January 2014 - 10:38 AM
Seats and door cards are back from the trimmers
Then we had a go at starting her up
No exhaust, no timing set up, mixture set roughly where we thought it should be
Turned it over a few times with no plugs in 5 seconds at a time to get oil everywhere & pull some fuel through to the carb. after that we put the plugs in but left the coil disconnected and went to 10 seconds of cranking. then we connected the coil, I held the choke on as we have no cable yet.
There she blows.
Jack even had a smile on his face
Edited by Cookiez, 26 September 2019 - 11:50 AM.
#38
Posted 23 January 2014 - 10:47 AM
This. is. AMAZING
#39
Posted 24 January 2014 - 12:49 PM
Now that Jack has tried the seat in
I don't like the look of the seat brackets
A quick think & a small modification later we have this, Just got to do the other 3 now
I think it looks better
Not many will notice.
#40
Posted 10 February 2014 - 04:18 PM
Right
Now its time to finish off the wiring
God this can be time consuming
Everything works, Jack didn't want the interior light in so we removed that.
We have run audio cables down the drivers side roof and straight into the boot
Boot pin for the alarm also goes down here
Alarm also in, just need to mount proximity sensors under the carpet.
Still no exhaust
It goes on Saturday or Monday to have this made.
#41
Posted 10 April 2014 - 08:01 AM
On the ramp at the exhaust company
Jack fitting bottom dashboard rail
Headlining goes in next,
This is after the first day, just letting it settle
Then Glass
Then onto the carpets
April the 1st, the old trick with a stand out of gaffa tape, Jack said it didn't fool him. he had to change his pants tho
Edited by Cookiez, 26 September 2019 - 11:53 AM.
#42
Posted 10 April 2014 - 08:27 AM
#43
Posted 10 April 2014 - 08:40 AM
Great work mate
It has defiantly come a long way and now it looks absolutely mint. Very nice Mini..
#44
Posted 15 April 2014 - 09:03 AM
Couple of pics of the exhaust
Doors on
She looks so small
Door Cards Fitted
Cardboard template for heel board & speakers
She has to have a final visit to the body shop soon, one of the seam strips has moved a little.
Wont be long now tho.....
I keep saying 2 weeks
Edited by Cookiez, 26 September 2019 - 11:55 AM.
#45
Posted 16 April 2014 - 06:02 AM
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
