Project Ruby - 1981 Hl
roundnose
229 replies to this topic
#181 Cookiez
Cookiez
  • 205 posts
Posted 31 May 2016 - 10:40 PM
Thanks Rocket
#182 Nikko
Nikko
  • 125 posts
Posted 10 July 2016 - 06:06 PM
Surely time for an update?
#183 joezone2001
joezone2001
  • 332 posts
Posted 17 July 2016 - 12:46 PM
Wow! I've not been keeping up to date on the forum for a while. Your car looks great! If mine looks half as good when it's done I will be over the moon! Keep up the great work. Joe
#184 Cookiez
Cookiez
  • 205 posts
Posted 26 July 2016 - 11:06 AM
I'm trying to put an update together
The company that Jack & Myself worked for went into administration.
May 25th
They got us all into the canteen, told us we wouldn't be getting paid, no redundancy, no money in lieu of notice.
Grab your belongings and leave.
Anyway a few weeks after this we were both employed again. This time we worked for different companies.
Ruby Two progress has been a little slow to say the least.
Motivation is picking up again so I will try my best to get something posted up this week.
#185 James_eaton_thewholething
  • 1,063 posts
Posted 26 July 2016 - 11:24 AM
Sorry to hear about the jobs. But at least you have both found employment again. Look forward to updates
#186 ryomini
ryomini
  • 583 posts
Posted 26 July 2016 - 01:24 PM
Like everyone says - you work hard and the details make the difference.  A lot of work.  My mini is kind of the opposite of yours.  I don't like cleaning vehicules much.  Yours is always very clean - amazing !
#187 Cookiez
Cookiez
  • 205 posts
Posted 26 July 2016 - 03:32 PM
Your not that far away
If you ever need a hand with anything, just ask. Your welcome here if you want to chat.
#188 Cookiez
Cookiez
  • 205 posts
Posted 31 July 2016 - 08:09 PM
Here goes
Not that much been happening,
The engine & gearbox was stripped back a little
It got a coat of etch
then silver & red
Washer Jet hole will have to be drilled out a little
Repainted the accelerator pedal
Purchased a replacement tank, The original one from Ruby was a little squashed, It didn't leak anywhere but I couldn't bring myself to use a squashed one.
If I've ever wanted to load Ruby on to a trailer there was never anywhere to attach anything to.
So O modified a Peugeot towing eye.
Changed the way we mount the front sub frame through the teardrop & front panel
And there you go
Also Jack has got a new mount for the go pro to fit on here.
New rear hub nut covers from DSN Classics
Alternator to bits, new bearings & carbon brushes
Rubbed all the casting marks out of the alloy ends
Quick coat of paint. Just waiting to do the fan white. Then it can go back together
Fitted the painted petrol tank
That's about it.
Been painting a set of wheels for Jacks other car.
Then had to dismantle the whole front end to take the DPF of to have a go at cleaning that.
Pack of oven cleaner & Caustic soda has worked wonders.
He says its like a new car again..
So this next week I really hope to be back on track building Ruby Two up
WITH NO DISTRACTIONS - JACK !!!!!
Edited by Cookiez, 02 October 2019 - 01:07 PM.
#189 Cookiez
Cookiez
  • 205 posts
Posted 20 October 2016 - 08:52 PM
Its about update time again On with the hubs, disks and callipers
The wheels have all been put together All the cap head bolts are facing the same way towards the edge of the rim
Wheel weights were painted to stop them oxidising
Fuel tank pipes were connected
Brakes & Clutch lines filled & bled
New Maniflow Inlet & Exhaust manifolds were purchased & test fitted,
The exhaust manifold is a just fit, had to remove the exhaust studs to get it in place. Its coming out again to get wrapped.
While the rest of the exhaust is off, I may as well give it a clean
Ready to bolt a few things back on the engine
Oh look, its floating
Its in.
Jack has had a new stainless washer bottle made
Exhaust Manifold wrapped, Just got to put the stainless fixing straps on at the ends.
That just about brings us up to date The rear hubs are all built up, handbrake cable has been painted & fitted.
Just had the exhaust connecting pipe made & welded. Jack is going to wrap the exhaust just past the gear selector box.
Then it can be fitted and put on her wheels for the first ever time.
At the moment Ruby Two is very dusty. She will have to go outside soon while I paint a few more bits in the garage.
I will give her a bit of a blow down with the air hose while she is outside. Thanks for reading everyone.
Edited by Cookiez, 01 October 2019 - 02:52 PM.
#190 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 October 2016 - 08:55 PM
:shades:
love it
#191 Nikko
Nikko
  • 125 posts
Posted 21 October 2016 - 07:11 AM
#192 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 21 October 2016 - 07:19 AM
Cracking job, some  nice Minis getting near completion on here at the moment!!
#193 MacGyver
MacGyver
  • 1,027 posts
Posted 22 October 2016 - 07:34 AM
WOW! 😯
#194 Cookiez
Cookiez
  • 205 posts
Posted 22 October 2016 - 02:46 PM
Had a problem putting the stainless bands on the exhaust wrap today
Can anyone recommend any decent ones
Ta
#195 Cookiez
Cookiez
  • 205 posts
Posted 27 November 2016 - 08:47 PM
Evening all
The exhaust wrap was secured with cv joint style clamps
Once complete this was fitted to the car
along with the new inlet manifold
The rest of the exhaust was wrapped just passed the gear selector
Polished and fitted
The manifold clamp was fitted with am aero nut and a pin to make sure it doesn't come undone
Battery cables were fitted, Changed the bolts to stainless ones
The new washer bottle was fitted
The boot sub box, amp rack, boot floor and covers were test fitted to ensure they still fit. THEY DIDNT !!!
Small changed need to be made we can get the same sort of fit that we had before
While the battery was connected we tested all the electrics and made a few changes to the alarm and lighting.
We made the side lights come on for 30 seconds when you disarm the alarm.
Its a bit slow progress at the mo.
Edited by Cookiez, 01 October 2019 - 03:04 PM.
