Project Ruby - 1981 Hl
roundnose
229 replies to this topic
#151 Cookiez
Cookiez
  • 205 posts
Posted 11 May 2016 - 07:50 AM
Ruby Two is home
Made up brake & fuel lines
I will remove them and give them a coat of paint before they are fitted for good
Wax oil tonight
Im going to be using an air fed sealey wax oil gun.
Edited by Cookiez, 26 September 2019 - 04:10 PM.
#152 Nikko
Nikko
  • 125 posts
Posted 11 May 2016 - 07:05 PM
Very impressed with the level of finish you're achieving. Not so impressed with the standard of heritage shell sold to you. You'd thing theyd churn out quality shells to ensure the mini lives on for as long as possible. You need to go into business, not many people would have your attention to detail.
#153 Cookiez
Cookiez
  • 205 posts
Posted 12 May 2016 - 09:29 AM
Thanks Nikko, Im just trying to do the best I can with what few skills I have.
It takes me a long time to do some things.
A few more bits that Jack is changing on Ruby Two
The standard shocks, 8.4 disks, Drive flanges and refurbed callipers from Ruby One will be for sale soon if any one wants them.
Saying that I have a big pile of stuff that will be for sale.
Sound deadening fitted back in roof.
Wax Oiled the subframe too last night.
I used an air powered sealey wax oil gun for the first time. What a great bit of kit that is.
Loads better than the pump action one that fits on the wax oil tin.
Edited by Cookiez, 26 September 2019 - 04:12 PM.
#154 Snoops
Snoops
    Just On Tickover
  • 5 posts
Posted 13 May 2016 - 12:53 PM
Great project and awesome attention to detail, such a shame about Ruby but Ruby 2 will be better for sure :) Keep up the good work.
#155 Cookiez
Cookiez
  • 205 posts
Posted 16 May 2016 - 10:51 AM
Spent most of Saturday cleaning up the engine & box getting it ready to paint
Wheeled Ruby Two outside in the sunshine
Brake & Fuel lines are now painted so we got them fitted
Stainless P Clips and bolts
Next we fitted the rear subframe
Edited by Cookiez, 26 September 2019 - 04:13 PM.
#156 Cookiez
Cookiez
  • 205 posts
Posted 17 May 2016 - 08:09 AM
I was fed up with the rubber covers on the radius arms perishing
I found an old silicone hose.
Chopped a slice off and pushed it onto the radius arm instead of the rubber cover
See how long this one lasts
Replaced the nut & washers with stainless ones
Garage Dog came to visit me last night
She was in her usual supervisory role
Edited by Cookiez, 26 September 2019 - 04:14 PM.
#157 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 17 May 2016 - 08:18 PM
Looks great, liking the silicone hose idea, what diameter is it? Nice supervisor too :thumbsup:
#158 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 18 May 2016 - 05:57 AM
This is stunning... this is a perfect build
#159 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 18 May 2016 - 08:58 AM
+1 on this! long time since built on a new shell,should remain free of rust for a few years  ;D
like all the mods you have done to make it better.
#160 alchall
alchall
  • Just Joined
  • 604 posts
Posted 18 May 2016 - 06:50 PM
Did you drill holes in the floor for the P clips before going to paint or did you weld in some captive bolts?
#161 alchall
alchall
  • Just Joined
  • 604 posts
Looks great by the way  :D
#162 James_eaton_thewholething
  • 1,063 posts
Posted 18 May 2016 - 06:52 PM
So excited to see this finished, love the paint
#163 Cookiez
Cookiez
  • 205 posts
Posted 19 May 2016 - 08:34 AM
Hi Alex
It wasnt a specific bit of silicone pipe, just one I purchased by mistake
The smaller side of the radius arm was easy to get it over.
The larger side was a struggle, but it went on.
Thank you, It means a lot when other people think what I'm doing is OK
We drilled holes and used stainless clench nuts
Then I welded them on the back, I know its going to the extreme. I have had one come loose and spin on me on the old shell
This was a chance to make sure it didnt happen again
They were all installed before it went to paint. and seam sealed round them.
When it came back from paint they were all tapped out to remove any paint that would cause problems fitting the bolts.
Hope this helps
Thanks James
The colour looks slightly different from Ruby One
The red is a lot brighter and the white is whiter
On Ruby one the white had a little bit of cream in it.
I supplied the Painter the codes of the original paint
Dunno if its anything to do with it but there is an extra coat of lacquer on Ruby Two
Edited by Cookiez, 26 September 2019 - 04:15 PM.
#164 alchall
alchall
  • Just Joined
  • 604 posts
Posted 19 May 2016 - 05:26 PM
Hope this helps
Thanks! that sounds like a neat solution and the result is nice and tidy, where did you get your clench nuts from?
#165 alex-95
alex-95
  • 6,025 posts
Posted 19 May 2016 - 07:17 PM
Hi Alex
Ok perfect, I'll get a bit of that, at least it won't perish in a few weeks time.
