Huge Clearout Of Engine Parts, Turbo Items, Cylinder Heads Etc Etc
27 replies to this topic
#1 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 22 October 2013 - 05:06 PM
I am a hoarder of mini parts (aren't we all?). I have this lot up for sale, in reality I will probably never end up using any of it. Items are reasonably priced, collection preferred from np4, but will post at buyers expense
T3 oil drain. Good order. I think this came off a ford t3, but will fit the metro T3, though the pipe may need shortening. £5
Metro turbo head 1. This came with a load of parts when I picked up a couple of turbo motors. i was told that it came from a gold seal engine. Sadly someone has removed 3 of the exhaust valves. A good genuine turbo casting though £sold
Unknown ?performance exhaust manifold. This also came wit engine parts that I bought a while ago. £10, now confirmed as an MG metro item - a good performance upgrade over standard mini items, cheap!
A+ Rockers. Removed from a Metro Turbo motor. £15
Oil Filter housing £5
Oil filter housing 2 £sold
Metro thermostat housing. Removed from an MG metro motor. £sold
MG metro turbo camshaft. Came out of a metty turbo lump. Some surface rust but could clean up fine £sold
Alternator 1, spins free.  £15
Alternator 2, also spins without problems £15
Coil, including bracket £10
1275 dizzy x2. these came with a pair of MG metro  turbo engines, but am unable to confirm if its an original turbo item. cast into the body is LUCAS 54403817, with 84193A, 4884 and 1185 to the plastic module respectively. if anyone can help to id these please let me know. £10 each
T3 metro turbo exhaust elbow £sold
Bolts and metal gasket for above £Sold
Servo Bracket £5
MG metro turbo throttle abutment plate £sold
?MG metro turbo plastic carb/ manifold spacer £6
[/URL]
Metro turbo inlet manifold. in good order, water pipes uncut, £sold
Hif 44, on a water heated inlet manifold. Have been told this is an MG metro item, cheap! £sold
Starter motor, £15
Turbo fuel pressure regulator, can include pipes, bracket etc £sold
Fuel pump, £5
Driveshafts, look to be straight, not sure if off a metro or mini £10
Duplex pulley, as shown £4
Cooper sport camshaft £20
used Duplex timing chain. Links E marked £10
water pump and pulley £5
MG metro turbo head, complete. part no stamped behind the thermostat housing. double valve springs. Looks to either be a very early head, or has had the guides done at some point as it does not have sodium filled valves. it was removed from a genuine turbo motor engine no 12HC16AA. £80
awaiting payment and collection
Pushrods, a bit rusty but could clean up, £5
That's about it for now, though I am slowly sorting my way through parts that I no longer require.
Pm me if you need any extra info, cheers, dan
Edited by welshdan, 29 November 2013 - 12:20 PM.
#2 Gremlin
Gremlin
  • 2,142 posts
Posted 22 October 2013 - 06:23 PM
Is the camshaft a normal MG Metro cam (not specific to turbos) and how much to post
#3 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 22 October 2013 - 06:27 PM
hi, thanks for the interest. the cam came out of an mg metro turbo lump
on a side note I have been told that both the exhaust manifold and carb/alloy inlet setup are both MG metro items.
Some good cheap performance items there, for a fraction of the ebay prices.
cheers, dan
#4 Gremlin
Gremlin
  • 2,142 posts
Posted 22 October 2013 - 06:28 PM
Just searched where you are, I'm happy to collect if it is a non turbo cam (if such thing exists)
#5 Gremlin
Gremlin
  • 2,142 posts
Posted 22 October 2013 - 06:42 PM
I understand it came out of a turbo, but is it any different to a normal mg metro
#6 cooperhawk
cooperhawk
  • 52 posts
Posted 23 October 2013 - 08:47 AM
Welshdan the cams don't have the 3 identifying rings  an  mg cam has.
#7 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 23 October 2013 - 09:19 AM
Thanks one is a turbo cam. One is a cooper sport cam
#8 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 24 October 2013 - 02:41 PM
Dizzys a tenner each. Open to reasonable offers on all this stuff
#9 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 24 October 2013 - 10:16 PM
also have this oil pressure gauge oil feed. never removed from the packet. £sold
also have a high boost turbo carb needle. again unused. £25
cheers, dan
Edited by welshdan, 13 November 2013 - 03:30 PM.
#10 Adzn2k
Adzn2k
  • 44 posts
Posted 26 October 2013 - 05:17 PM
Would you take 60 for the head with all the valves?
#11 pierres
pierres
  • 586 posts
  • Local Club: No
Posted 26 October 2013 - 06:04 PM
also have this oil pressure gauge oil feed. never removed from the packet. £5.
cheers, dan
Have you got the adapter to go with this ??
#12 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 26 October 2013 - 08:46 PM
No sorry , but they can be picked up cheaply!! Cheers
#13 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 29 October 2013 - 09:13 PM
Some parts sold, will update list tomorrow. Get in touch if you are interested in anything
#14 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 31 October 2013 - 12:56 PM
open to reasonable offers. would rather this stuff put to use than scrapped.
cheers, dan
#15 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 01 November 2013 - 12:15 PM
Metro cam sold. Other parts still available
