Front Suspension Top Arms Bearing Removal
Best Answer cian , 26 October 2013 - 09:11 AM
Great work tiger99 Go to the full post
18 replies to this topic
#1 Shaley
Shaley
  • 154 posts
Posted 21 October 2013 - 09:23 PM
Ok is there a secret to removing the needle roller bearings from the front arms?
Struggled like mad to remove them
Thanks in advance
#2 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 21 October 2013 - 09:28 PM
Tap them out with a drift they shoud just plop out. Use the old one as a drift to put the news one in.
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 21 October 2013 - 10:48 PM
Attached File  IMG_3537.jpg   31.89K   48 downloads
made a quick and nasty tool to knock them out, behind the bearing is a gap, hook of the tool gets in the gap ..
insert from opposite end to bearing you are removing
#4 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 22 October 2013 - 08:36 AM
Wonder did bmc have a tool to remove them back in the day
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 October 2013 - 09:00 AM
Yes, it's called a bearing puller...
this'll do the job plus quite a few others...
http://www.machinema...ring-puller-set
#6 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 22 October 2013 - 09:02 AM
#7 cian
cian
  • 869 posts
Posted 22 October 2013 - 11:12 AM
Bought a set to see if they where as good as people said and they didnt do squat! That one looks like the proper tool vipernoir!
#8 Vipernoir
Vipernoir
  • 782 posts
Posted 25 October 2013 - 04:27 PM
Proper tools are the only way to go if you can get hold of them,
#9 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 25 October 2013 - 05:16 PM
The problem with the proper tool is £70 is a lot of money to spend on a tool that will only be used once or twice. It seems my toolbox is full of such tools (cone compression and clutch oil seal tools come to mind) .
There are lots of ways of removing bearings without the proper tool that do just as good a job. Have a search on here for top arm bearing removal.
#10 cian
cian
  • 869 posts
Posted 25 October 2013 - 07:01 PM
Can u buy the tool!? I assumed they would be long since dissapeared or people who have them wont sell them
#11 HarrysMini
HarrysMini
  • 3,352 posts
Posted 25 October 2013 - 07:29 PM
Did you even read Guesswork's post?
#12 cian
cian
  • 869 posts
Posted 25 October 2013 - 08:29 PM
Yep sure did but those are nothing like the video
#13 tiger99
tiger99
  • 8,584 posts
Posted 26 October 2013 - 08:52 AM
Bearing pullers are readily available, if a bit expensive. They are not specific to the Mini, as needle rollers are used in many places. Don't bother with the slide hammer type, as a very tight bearing (common on Minis) needs something more powerful. Or, get a slide hammer type and be prepared to fit some kind of spacer and nut so you can apply a more positive pull
See here for lots of pulling equipment:
http://www.bearing-king.co.uk/kukko
This shows how to use it and what bits, such as the counterstay, you need:
http://www.baumtools...cting_tools.pdf
Or Amazon do a set:
http://www.amazon.co...r/dp/B00392Z6NM
This article by Timken shows several techniques for different situations:
http://www.timken.co...l _Part1of3.pdf
This bodge may work:
http://toolmonger.co...blind-bearings/
Here are some "proper" tools:
http://www.qbcbearin...rs_MP_63-64.htm
Finally, this shows the bearings on a rear radius arm being extracted, exactly the same principle.
http://mk1-forum.net...php?f=18&t=5984
As always, Google will get you the answers quicker than any forum. Try searching for "bearing extractor" or "internal bearing puller" etc
Edited by tiger99, 26 October 2013 - 08:54 AM.
#14 cian
cian
  • 869 posts
Posted 26 October 2013 - 09:11 AM   Best Answer
Great work tiger99
#15 MiniTim71
MiniTim71
  • 36 posts
Posted 26 May 2021 - 08:20 PM
This looks like a very simple way to do it.
I am planning a total front suspension rebuild and have bought some M7 x 22mm washers to see if this works ....
