My Mini 1000 1975 Mk3 Restoration Project
roundnose
199 replies to this topic
#46 BUNYIP
BUNYIP
  • 67 posts
Posted 26 February 2014 - 10:32 AM
Thank you !
i have fitted the bonnet once, but i was not all that happy with the gaps. down near the grill there was only a very small gap. (around 3mm) but near the windscreen surround it was far form that. (around 8 mm)   - so I'm thinking little on grinding the wing a little where it meets the innerwing..
i don't have a pic of it. but i can take one later or tomorrow
i had this problem also, i ground the lip of the wing to pull the gap in worked out ok, although i had the gaps set at 4 - 5 mm. i also had to panel beat the wing around the scuttle area to accommadate 'pushing the wings in'.
with regards the A panel.  the contact lip between wing and a panel i plug welded every 50mm, may be over the top but better that than it coming apart. were the a panel is folded around the door pillar i but a little stitch weld approx 5-10mm every 75mm sprayed with etch primer and then tiger sealed all joints.  hope this helps
#47 Nino
Nino
  • 178 posts
Posted 26 February 2014 - 03:56 PM
I will try to get some pics Mk3 cooper s, but i haven't welded it yet. so not much to see on the pics..
Bunyip. Thanks ! :)
ill have to such a bit more. because i really wonna weld it just like they didt it in the factory :) but yes i agree, don't want any thing to crack or fall apart when its done ! :) - again thanks. :)
#48 Matt Zane
Matt Zane
  • 217 posts
Posted 26 February 2014 - 10:56 PM
Fantastic work so far! Keep it up!
#49 Nino
Nino
  • 178 posts
Posted 14 March 2014 - 01:10 PM
So new update, i started one with welding the front after weeks of adjusting. finally I'm happy with the gaps.
i just blasted these, so i could trial fit the subframe
almost the same
this was the old gaps. IMG_4310_zps37814e36.jpgIMG_4563_zps5eeb3965.jpgIMG_4564_zps0fc59b19.jpg
straightened the inner wings and made holes in them
i finally got happy the gaps by welding the thiny spot between my front wings to the scuttle. near the bonnet. and then strapping them down to the right position.
IMG_4590_zps293dc5cd.jpgIMG_4593_zps7c0acfa9.jpgIMG_4621_zpsb1651497.jpgIMG_4622_zpsa184b563.jpg
happy ! so i started :) :D
IMG_4595_zps67b588d2.jpgIMG_4633_zps870e2ccf.jpgIMG_4634_zpsd5dee1f6.jpgIMG_4636_zps321f7035.jpgIMG_4640_zpsda2f5833.jpgIMG_4641_zps8f94b9ac.jpgIMG_4642_zpsffec0063.jpgIMG_4644_zps4982a242.jpgIMG_4643_zps71900974.jpg
Thats if for now. I'm replacing the LHD door skin before welding the other a panel :)
Hope you guys enjoy !
cheers Nino
#50 Nino
Nino
  • 178 posts
Posted 14 March 2014 - 07:41 PM
Hi again :)
i swapped the new door skin with a complet great condition LHD door my father had today.
i just fit'd much much better then my old door.
so i could finish the welding on the front today :)
IMG_4657_zps20327b1c.jpgIMG_4655_zps24c55c41.jpgIMG_4658_zps12ae2e5f.jpgIMG_4659_zps32aa1fad.jpgIMG_4661_zps79ab76b6.jpgIMG_4662_zps8f28086a.jpg
so now i am going to grind the welds down.
Pics will come in a few days :)
I only need to weld the outer sills and the rear valance and then there is a finish'd shell :D ! !
Cheers Nino
#51 HARRYSPADGE
HARRYSPADGE
  • 19 posts
Posted 14 March 2014 - 08:08 PM
Very nice work, I'm hopefully going to start work on my Mk3 this weekend.
The weather has finally turned nice so I can get outside, unfortunately I don't have a garage or workshop which certainly helps when trying to restore these Minis.
#52 Nino
Nino
  • 178 posts
Posted 14 March 2014 - 11:42 PM
Thank you very much Harryspadge :)
yes its just a lot easier when you have a nice garage for it - do you have a thread on yours ? :)
- Nino
#53 MR J
MR J
  • 416 posts
  • Local Club: Doncaster Mini Owners
Posted 15 March 2014 - 01:12 AM
Very nice build Nino, would love a MK3 myself to restore.
#54 jpw1275
jpw1275
  • 2,803 posts
Posted 15 March 2014 - 07:35 AM
Superb work nino , I've just started on my mk3 after 5 years of ownership...... I'm going to weld all the braces in this weekend ready for surgery...... Your pictures will help a lot
Cheers james
#55 Nino
Nino
  • 178 posts
Posted 15 March 2014 - 09:10 AM
Thank you both very much, glad you're enjoying :)
MR J
do you have currently ? :)
jpw1275
Thats kinda like me, mine was taken apart by me and my father about 7 years ago(when i was 14 years old), and then he didn't have time for it. So i just got my own garage and started September 2013 :)  - i just wanted a Mini for IMM '14 :)
I really hope that the pictures will help you out, the 3mm square iron tubes really work'd well on mine :)
Kind regrads Nino :)
#56 NZMini1275
NZMini1275
  • 227 posts
Posted 15 March 2014 - 10:33 AM
This is looking great. You have made good progress on the bodywork. I struggled a bit on mine and i had a lot less panels to replace.
#57 Nino
Nino
  • 178 posts
Posted 15 March 2014 - 11:39 AM
Thanks NZMini1275 :)
i have also had some hard weeks with the body work. but i gotta say that the front was the hardest.. it took a looooong time before i was happy with all the gaps :)
- Nino :)
#58 MR J
MR J
  • 416 posts
Posted 15 March 2014 - 09:19 PM
MR J
I have a 94 Sprite spi and a low mileage original 88 Jet Black, also a 87 MR2 Mk1b.
Really like the look of a proper Mk3!!
#59 Nino
Nino
  • 178 posts
Posted 15 March 2014 - 09:56 PM
MR J
Cool ! do you have any threads of them ? :)
A proper Mk3 i very lovely with the right parts, but well, i would always want a MK1 :)
-Cheers :)
#60 MR J
MR J
  • 416 posts
Posted 16 March 2014 - 08:45 PM
MR J
-Cheers :)
Here's a thread for my 94 Sprite.
http://www.theminifo...sprite-rebuild/
Here is my Jet Black, really need to update this one as I finished it a year ago.
http://www.theminifo...ck-garage-find/
Edited by MR J, 16 March 2014 - 09:02 PM.
