I meant the actual differential, if there's some confusion with final drives. A cross-pin one is good insurance against expensive breakages, even a Quaife if you can run to the cost and want to use it for some competition driving.
#16
Posted 12 October 2013 - 12:41 AM
#17
Posted 12 October 2013 - 06:53 AM
The need for a SC CR gearbox is determined by the cam. If you have a 286 of hotter cam, then a 286 is needed because of the narrower rev range in each gear. But then a low final drive ratio is needed to enable good acceleration in the high first gear.
I recommend going to 1330 cc as when the engine needs re-boring again the block will not be scrap. There is very little difference, if any, in power output.
always accurate straight, honest and educated advise as usual.
s/c on a everyday road car cannot be nice. if you want to go that way ive dogbox foresale £800
#18
Posted 13 August 2023 - 10:20 PM
also do i need a straight cut gearbox or is there no need?
Yes, it's the law ๐
#19
Posted 14 August 2023 - 06:51 AM
If it is a weekend burner then crack on.. such a fun noise but for a daily... headache..
#20
Posted 14 August 2023 - 12:59 PM
Do Mini Spares still make the helical close ratio gears? They were launched after we did our last engine some years ago which has a SW10 cam wo we fitted S/C ST Abingdon ratio with a 3.76 diff. I don't mind the noise as we only use it locally but I could see it getting very annoying on a long journey. The Mini Spares helical set seemed to be the perfect answer for a fast road car.
#21
Posted 14 August 2023 - 01:04 PM
Think of this?
https://www.minispar...ical~gears.aspx
#22
Posted 14 August 2023 - 01:30 PM
On another note has anibody used a 1380 engine from minisport? are they any good? as thats the engine and box im leaning towards!
on the brake subject what about the m1155 are they a bit to much for a fast road and ocasional track day?
Search this forum for experiences with MiniSport... There are some people with opinions about this shop based on their first-hand experiences...
Edited by fokko, 14 August 2023 - 01:30 PM.
#23
Posted 14 August 2023 - 04:08 PM
#24
Posted 15 August 2023 - 12:57 PM
People will always tell of badmservice.. few actually say when they get good service.....
Maybe thatโs why you hear so little complaints about MiniSpares?
#25
Posted 18 August 2023 - 03:07 PM
When that engine needs a rebore the block may well be scrap or need some special sleeves made for it.
Personally I never go more than +0.060 overbore which gives 1330cc. Offset bore is not required and when a further re-bore is needed it's simple to just have standard sleeves fitted.
Except for serious competition I have never seen any noticeable power increase at 1380 on a road or rally car. One might think that 1380 is just for bragging rights in the pub ๐
Also tagged with one or more of these keywords: engine, suspension, brakes
Mini Technical Sections →
Problems, Questions and Technical →
Lower Radiator Bracket Fitment IssuesStarted by DAC1952 , 09 Mar 2025 ![]() |
Automatic GearboxStarted by astracass , 25 Feb 2025 ![]() |
Start Motor Grind No Engine Turn OverStarted by MrNowell , 16 Feb 2025 ![]() |
Tie Bar Bushes - What Do I Need?Started by daddums , 09 Feb 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
