Road Gear Box For Big Power
Posted 08 October 2013 - 11:22 PM
I know its not the clearest question but any help would be appreciated.at this stage im not looking at any budget but mire at whats technically possible as this is my dream and won't be happening for a few years yet!
Posted 09 October 2013 - 12:51 AM
5 speeds have the potential to be weaker as you are either adding bits & running indirect drive in the highest gear or you're squeezing an extra gear in the original space that makes 'em thinner. I've no practical experience to say whether that's more than compensated for by higher grade materials. If you're using forced induction, then you'll be making much of the extra power by increasing the torque that will negate some of the reason to have closer ratios. I think there's a fair few on Turbo Minis running stock gearboxes. Upgrading the diff & not pointlessly dumping the clutch to shred your tyres seems to do enough. There are a few enhancements possible, like a higher grade layshaft and KAD's extra bearing housing from their 5 speed.
You can think of a Turbo as a sort of overdrive - it increases the amount air going through the engine, which is what changing down a gear also does.
