Fitting Harnesses
38 replies to this topic
#31 samsfern
samsfern
  • 5,243 posts
Posted 10 October 2013 - 05:07 PM
I wouldn't want one of those harness bars, especially bolted to the rear arches. The forces in a crash can be massive.
Do it properly and tie the harness bar in with the roll cage.
I had a harness bar bolted to the arches in my old mini, I had a car crash into the rear quarter of it at around 30 mph, and it actually took the impact quite well, the bar didn't bend, the arches bent around it.
#32 rally1380
rally1380
  • 1,893 posts
Posted 10 October 2013 - 05:39 PM
I think it's because you can't lean down if the roof does cave in?
Perhaps, but a roof caving in doesn't happen in slow motion giving you enough time to duck!
#33 waddle
waddle
  • 536 posts
Posted 09 December 2013 - 12:27 AM
id be worried that there was any deformation from the harnes bar or surrounding areas in a 30 mph crash, although i suppose it could have been because you got shunted in the rear rather than the force exerted on it by the harnesses
#34 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 09 December 2013 - 09:31 PM
Safety Devices harness bar.  Get one of them.  They're dear, but it's your life you're talking about.  Get a rear cage, with diagonal and a SD harness bar.
#35 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 09 December 2013 - 09:33 PM
That's what I've got in mine:
#36 merther
merther
  • 147 posts
Posted 11 January 2014 - 09:42 AM
Has anyone been able to fit the eyelets for the lap belts directly into the existing seat belt mounts? Wondering about different thread etc, car is an 63 mk1.
#37 grumpy dad
grumpy dad
  • 305 posts
Posted 11 January 2014 - 10:57 AM
Hi
yes all the eyelets I have used have a course thread
and the bolt for seatbelts is much finer
so you will have to use plates
#38 adamg1380
adamg1380
  • 141 posts
Posted 14 January 2014 - 04:52 PM
If you've got a roll cage you can often replace one roll cage bolt with an eyelet bolt for the outside one, and the foot of the cage makes a nice spreader as well.
#39 fwdracer
fwdracer
  • 269 posts
  • Local Club: Mini7 Racing Club
Posted 21 January 2014 - 01:19 PM
This is a picture of the only properly safe proposal quoted on this entire thread. Harness bar on the cage with the belts out horizontally. By the (Blue) Book! Good man. Clearly values his personal safety. 4-points done badly are less safe than OE seatbelts.
Edited by fwdracer, 21 January 2014 - 01:21 PM.
