Hi Guys,
I will try and give as much info as I can and if i miss any details that affect value please let me know, thanks.
Ok so:
- The head came off a 1293cc engine built for hillclimb events.
- It has heavy duty double valve springs, bronze guides and has had porting and polishing performed on it.
- It had 1.5.1 rockers fitted.
- It has a bypass plug/blocker fitted to the thermostat end, this was fitted to heat the thermostat end quicker to avoid the inevitable colder on one side issue. To me this was an important mod when I purchased the engine as I didnt want a wonky head.
- The engine was running prior to disassembly, when taken off I made sure the correct loosening sequence was performed
The head has these numbers stamped on it:
OSC . UK
0272
SQ.1.NL
Finally here are some photos.
At this moment in time I am unsure If i want to sell, it depends on what work needs doing to the head. Thanks in advance for any help/advice you can give me
Lewis
Edited by lewis, 08 October 2013 - 11:39 AM.
