1.4 K Series Question.
22 replies to this topic
#1 bluemini1979
bluemini1979
  • 619 posts
  • Local Club: Colchester Mini Club
Posted 06 October 2013 - 06:20 PM
Hi im planning on doing the conversion to my 76 clubby. Im looking at all the options for subframe. if I use the standard metro frame can I still use the ten inch wheel conversion? I am aware this widens the track of the front but how do people widen the rear to the same track? Also if I wasn't to use the metro subby how hard is it to modify the original with lining up in mind. How do you know where to put the engine in the frame?
#2 Artstu
Artstu
  • 829 posts
Posted 06 October 2013 - 06:35 PM
just put it here
#3 bluemini1979
bluemini1979
  • 619 posts
Posted 06 October 2013 - 06:38 PM
have you got any other pictures of the frame? with out the engine in and any dimensions? Thanks for the reply.
#4 Artstu
Artstu
  • 829 posts
Posted 06 October 2013 - 06:42 PM
sorry it's from the Allspeed site http://www.allspeede...rbox-r65-detail
#5 bluemini1979
bluemini1979
  • 619 posts
Posted 06 October 2013 - 06:48 PM
oh right thanks
#6 Artstu
Artstu
  • 829 posts
Posted 06 October 2013 - 07:14 PM
Have you looked at the Rover builds?
http://www.16vminicl...isplay.php?f=24
http://www.theminifo...orum/165-rover/
#7 bluemini1979
bluemini1979
  • 619 posts
Posted 06 October 2013 - 08:48 PM
Yeah I've been looking through them but can't find anyone with dimensions or detailed pics of subframe and how it's built. I found one that had pictures as they went long but it didn't look very strong considering the power going through it. They had taken almost all the material out of the box section for the alternator belt to clear but didn't add any additional bracing :/
#8 Minidarren83
Minidarren83
  • 1,207 posts
Posted 09 October 2013 - 07:14 PM
Have a look through mine there is a link in my sig below and here it is on 16v
http://www.16vminicl...ead.php?t=32188
Most frames that people build are one offs so are just made to fit the engine in the car like mine so long as the bottom arms clear the gearbox and the top arms are somewhere close to the engine mounts and it fits under the front then your golden
Make yourself a jig up to keep all the main points straight and to keep the towers aligned
#9 bluemini1979
bluemini1979
  • 619 posts
Posted 20 October 2013 - 05:29 PM
would the 4 pot 7.5 brakes be sufficient or should I go for 8.4 brake set up?
#10 Minidarren83
Minidarren83
  • 1,207 posts
Posted 21 October 2013 - 07:01 PM
The 7.5 4 pots are far better than standard 8.4 unless you go for 4 pot 8.4 vented as on the metro/mini turbo
#11 bluemini1979
bluemini1979
  • 619 posts
Posted 08 November 2013 - 07:22 PM
Can I take the 1.4 out of a k series'd metro?
#12 Artstu
Artstu
  • 829 posts
Posted 08 November 2013 - 07:26 PM
As long as you ask for the owners permission to do so first  :P is this a trick question?
#13 bluemini1979
bluemini1979
  • 619 posts
Posted 08 November 2013 - 07:31 PM
No not a trick question just no of several in a scrap yard near by. If it's got the right engine in to do the conversion I'll go buy one as a donor
#14 Broomer
Broomer
  • 1,771 posts
Posted 08 November 2013 - 07:38 PM
you will need the ECU, key fobs and 5AS to go with it.
#15 bluemini1979
bluemini1979
  • 619 posts
Posted 08 November 2013 - 08:03 PM
Yeah they are still with the cars. Planning on buying the whole car not just the engine
