Hi all, just bought a very nice condition 12g295 head, its had approximately 16 thou skimmed from standard and I have worked out that there is 124 thou of metal between the head surface and the oil way - approximately how much will need to be skimmed to fit this to a standard 998 with dished pistons? I am only looking for an approximate value as I am yet to measure the dish or the compression ratio, both which will be done when I remove the standard head. My question is: can this head be safely skimmed to fit my engine, with 124 thou of metal left to play with?
12G295 Head Skimming For Dished Pistons - Possible?
Posted 29 September 2013 - 03:40 PM
Posted 29 September 2013 - 06:26 PM
Posted 29 September 2013 - 06:43 PM
Is that 80 thou above the oil path? I know I need to do the calcs, which will be done when I get round to removing the head, I just need to know if anyone has put a 295 on an engine with dished pistons, ie if it is possible if you see what I mean? Not looking for an accurate figure of how much to remove :)
Posted 29 September 2013 - 07:05 PM
Posted 29 September 2013 - 07:20 PM
Ah right I see, thanks - I had come across the 2.75" figure for the thickness on several threads before I started this one and mine measures at 2.734", thats how I arrived at the conclusion that it has had a 16 thou skim at some point previously :) So you reckon around 80 thou needs to come off a 2.75" non skimmed head to run with dished pistons? Sounds about right, thanks for the help mate.
Posted 29 September 2013 - 07:23 PM
Posted 29 September 2013 - 08:53 PM
The heads must vary abit if mine only had 140 thou pre-skim before the oil way was broke! One last question, what would be a "safe" amount of metal to leave between the oil way and the surface? Would 1mm be too little?
Posted 29 September 2013 - 11:08 PM
Ac
Posted 29 September 2013 - 11:51 PM
Thanks for the advice AC - what would you call too big a skim? Would 60 thou between the oil path and deck outer surface be too little?
Posted 30 September 2013 - 07:36 AM
Ac
Edited by ACDodd, 30 September 2013 - 07:38 AM.
