Hi all. I need to do a lot of welding to my car then planning to sand down and primer up.
I was thinking of using a weld through zinc primer on and around the welds, then a red oxide or grey primer on the rest of the body to prepare for a respray.
Are these the correct primers to use and which should I choose, red oxide or grey primer? baring in mind the body will be silver and roof black, eventually
Any guidance would be great, thank you
