Snap On Timing Light
13 replies to this topic
#1 Guest_mark clark_*
Guest_mark clark_*
  • Guests
Posted 19 September 2013 - 11:26 AM
I recently bought a second hand Snap On (MT1261A) timing light but there was a rattle coming from the inductive pick up. I took it apart and the silver clip on the right of the photo fell out. I've tried to figure out where it's supposed to go without success. Any ideas?
Attached File  image.jpg   50.42K   47 downloads
#2 the_samkingdon15
the_samkingdon15
    formally known as samkingd0n
  • 644 posts
  • Local Club: I ride alone
Posted 19 September 2013 - 12:25 PM
all snap on tools have a lifetime warranty.. send it off and they'll fix it..
we found a 40 year old ratchet and they fixed it :D
#3 Guest_mark clark_*
Guest_mark clark_*
  • Guests
Posted 19 September 2013 - 01:49 PM
Yeah I know but just wanted to know if anybody could give us a clue before I go down that road. Snap On don't have any exploded diagrams to reference.
#4 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 19 September 2013 - 01:53 PM
from the looks of it the spring loaded bit that ususlly clamps over the ht lead isnt closing so i would assume its something to do with the spring mechanism
#5 R1mini
R1mini
  • 1,387 posts
Posted 19 September 2013 - 02:00 PM
Send it off where? I have a rachet that has broken and the local snap on dealer who I didn't buy it from doesn't want to know
David
#6 the_samkingdon15
the_samkingdon15
  • 644 posts
Posted 19 September 2013 - 02:35 PM
David
well I went to a dealer and he just took it and sent it off.. 2 weeks later it came back fixed :)
#7 Guest_mark clark_*
Guest_mark clark_*
  • Guests
Posted 19 September 2013 - 02:46 PM
Danie....when it's reassembled, the spring mechanism works perfectly!
#8 Spud_133
Spud_133
    mmm potato and cheese....
  • 1,689 posts
  • Local Club: C&T Classics
Posted 19 September 2013 - 04:00 PM
Is it not a wire retaining clamp type thing?
#9 Barman
Barman
  • 1,068 posts
Posted 19 September 2013 - 04:25 PM
If it works perfectly without it, throw it away and remove it from your thoughts forever....
Your Mini will present you with many, many more things to worry about....
#10 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 19 September 2013 - 04:28 PM
that looks possible too!
#11 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 19 September 2013 - 04:40 PM
some snap on dealers are better than others
#12 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 21 September 2013 - 01:29 PM
You said that this is a second hand light and that the clamp works fine when put back together.
I believe it is working fine because that part has nothing to do with the light and is something its previous owner somehow managed to drop into the clamp assembly.
That part is a retaining ring commonly called an "X-washer" in the U.S.  They are used for mechanical assemblies, not electrical ones (typically).  I regularly see them used on parking brake actuating arms on Japanese and American cars as well as other assemblies.  The clip is placed on a metal shaft with a groove cut in it and pliers are then used to squeeze the legs of the clip together to secure the semi-circular cutouts in the clip in the groove.  I see no way/place for that clip to be used inside the light's pickup clamp assembly.
Not sure if the links will work but, the image below should show how this type of clip is typically used.
http://images2.mcmas...ng?ver=34184477
90102a037p2l.png?ver=34184477
#13 Guest_mark clark_*
Guest_mark clark_*
  • Guests
Posted 21 September 2013 - 01:49 PM
Top man! Very strange how it got in there...the unit didn't look like it had been opened before.
#14 charie t
charie t
  • 3,153 posts
Posted 21 September 2013 - 03:11 PM
no they don't, only hand tools come under the lifetime warranty
