Edited by minilee94, 19 September 2013 - 06:42 PM.
Straight Cut Gears Worth It ?
#31
Posted 19 September 2013 - 06:40 PM
#32
Posted 19 September 2013 - 07:12 PM
For the Mini I've not seen any SC gears which were not part of a close ratio set. The reason the close ratio gears are straight cut is because they are cheaper & easier to machine than the stronger helical ones and the sales volume for close ratio gears is small. If they made them I would buy the SC ratios in helical form, but no-one does, so far as I know.
It would be uneconomical to have a batch of helical close ratio gears machined up and they would be very expensive if that were done.
#33
Posted 19 September 2013 - 07:23 PM
The power band cam I am going to get is 2000 to 7000
I have not chosen a FD if it helps I'm going to use helical drop gears
#34
Posted 19 September 2013 - 07:31 PM
I think you will probably be OK with a standard gearbox and a 3.76:1 FDR, especially if it is to be a road car. No point in spending money for no actual performance gain.
If the power band is 2k to 7k then it's a fairly mild cam, so the power band will not be narrow enough to justify CR gears.
#35
Posted 19 September 2013 - 08:20 PM
1 I wanted to
2 because 2 of my gears are ruined
#36
Posted 19 September 2013 - 08:37 PM
I was speaking to a guy the other day and he tells me nowadays f1 cars used syncro mesh gears that are helical, and not s/c dogs anymore
#37
Posted 19 September 2013 - 08:47 PM
f1 cars all have electronic sequential gearboxes now too. There's really no point in comparing that in any way to a 1960s design of a budget road car.
#38
Posted 19 September 2013 - 08:50 PM
It wasnt meant as a comparison, just letting people know.
Its quite interesting as most people think s/c gear are the be all and end all.
#39
Posted 19 September 2013 - 09:08 PM
For the OP's car, the best gear ratios would be the original Cooper 'S' ones. There really is little point in having SC gears for a road car with a fairly mild cam. In fact the high first gear will reduce the acceleration compared with a standard gearbox, a 3.76 FDR and a fairly mild cam (up to a 276 for example).
#40
Posted 19 September 2013 - 09:20 PM
I have a cooper s gearbox foresale too.
#41
Posted 20 September 2013 - 05:16 AM
So as I'm keeping the original 1st gear surely that's cured the problem or not ?
#42
Posted 20 September 2013 - 06:11 AM
#43
Posted 20 September 2013 - 09:48 AM
The kit Im thinking of buying doesn't come with 1st gear. So I use standard 1st gear that's in the box . So as your saying about the acceleration will be poor because of the cam .
Surely the low 1st gear with the higher 2nd gear from a SC CR set will give a HUGE gap between 1st & 2nd.
If fitting SC CR gears they must be fitted as a complete 4-speed set so that they perform as intended in keeping a narrow power band high-revving engine 'on the cam'. With a standard low 1st and the high 2nd it will quite simply 'bog down' when the change to 2nd is made.
#44
Posted 20 September 2013 - 10:27 AM
Well I was only guna go straight cut as
1 I wanted to
You've answered your own question there
#45
Posted 20 September 2013 - 11:07 AM
Yes a SC 2rd gear ratio (about 1.7) is quite close to "standard A+" 3rd gear ratio (1.45) ... So just try jumping from 1st (3.6 ratio) to 3rd gear on a normal box and you'll get an idea. Basically if you push 1st gear to 6000RPM you would get down to 3000RPM, not very advisable...
