Stuck Valve :(
20 replies to this topic
#1 oliver122
oliver122
  • 1,007 posts
Posted 14 September 2013 - 07:07 PM
Hey guys so one of my valves have stuck open :( now i was wondering is it a job i can do at home to remove or is it a send it off jobbie any help would be great tar
#2 bpirie1000
bpirie1000
  • Area Managers
  • 2,343 posts
  • Local Club: Amoc
Posted 14 September 2013 - 07:22 PM
Could do it at home depending on your experience.
Remove the head gasket. Have a look at the valve. If this is the first time you have done this then deafo not for you to do....
Check piston.. Clean it thoroughly and inspect for wobble...(technical term) if this is news to you again deafo for someone else to do...
Good luck either way..
As mentioned before.. If it is a 998, consider upgrade to a 1275.. May cost you but power increase will be worth it and replacement canbe done in 45 minutes..( did this before across country run)
Again good luck...
#3 mini13
mini13
  • 3,810 posts
Posted 14 September 2013 - 07:24 PM
Valves dont normally just stick open, it could be bent,
head off, remove valve check it...
#4 oliver122
oliver122
  • 1,007 posts
Posted 14 September 2013 - 07:26 PM
Well im an engineering apprentice and like giving anything ago , its a 1275 motor anyway with a worked head , i know its running slightly rich because of im running a 276 cam
Thanks for the reply
#5 mini13
mini13
  • 3,810 posts
Posted 14 September 2013 - 07:32 PM
you should deffo give it a crack then,
pretty easy to get a mini head off... manifolds of (5 nuts) top rad hose and heater hose off, rocker cover off, head nuts off, rockers off, push rods out, head off.
#6 bpirie1000
bpirie1000
  • Area Managers
  • 2,343 posts
  • Local Club: Amoc
Posted 14 September 2013 - 07:34 PM
Rip the head aff.....have a look.. Trying to cover all elements of experience on here...
#7 oliver122
oliver122
  • 1,007 posts
Posted 14 September 2013 - 07:35 PM
Whats the best way to remove the valve as its stuck down i should imagine it will be hard to get out ?
#8 mini13
mini13
  • 3,810 posts
Posted 14 September 2013 - 07:50 PM
you should be able to get the collets out and the spring off, then use a drift to see if it will com out, I reckon it will.
#9 oliver122
oliver122
  • 1,007 posts
Posted 14 September 2013 - 07:57 PM
Cheers bud once its out and i can inspect it if it looks to be straight what should be done then , if its bent i take its a case of a new guide and valve
#10 mini13
mini13
  • 3,810 posts
Posted 14 September 2013 - 08:03 PM
basically yeah,
with the valve out, lay the stem on a table/flat surface and roll it... its amazing how small a bend this will show,
if the bend is small you should  get away with the existing valve, but if you do replace the guide the seat will need recutting, a job for an expert,
#11 oliver122
oliver122
  • 1,007 posts
Posted 14 September 2013 - 08:06 PM
So if its straight can it be put back in without an issue ?
#12 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 14 September 2013 - 08:13 PM
If its bent it needs replacing!
#13 mini13
mini13
  • 3,810 posts
Posted 14 September 2013 - 08:17 PM
if there is an obvious reason why it was sticking that can be rectified then yes....
if the valve stem is all marked then it'll need replacing, fortunatly mini valves are only a few quid each.
#14 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 September 2013 - 02:45 PM
Whys its stuck is the important question, how did it happen ?
#15 oliver122
oliver122
  • 1,007 posts
Posted 16 September 2013 - 09:33 AM
i was just driving down the road about 40 ish in 3rd/4th , i then went to accelerate and it started to miss so i pulled in to the side , tuned the engine off checked all connections and tried to start it up again but without any throttle it would not start and eve on full throttle it would not rev above 1k rpm and its the 3rd valve along going from thermostat side of the head
Edited by oliver122, 16 September 2013 - 09:35 AM.
