Supercharger Belt Slap
17 replies to this topic
#1 minivanman8
minivanman8
    Previously known as minimadandy.
  • 426 posts
Posted 07 September 2013 - 08:30 PM
How do you guys get the charger belt tight enough to avoid slap?
I can't seem to get enough tension on my belt to stop it.
#2 jeebz
jeebz
  • 155 posts
Posted 08 September 2013 - 01:07 PM
Use a shorter belt or use a stretch belt with a slightly higher elastic modulus.
#3 minivanman8
minivanman8
  • 426 posts
Posted 08 September 2013 - 04:14 PM
I can't see how a shorter nelt will help as I'd still have to tension it!  I seem to have got it tight enough now :)  Just now strugging with a loud 'tappety' noise which isn't coming from the tappets :(
#4 jeebz
jeebz
  • 155 posts
Posted 08 September 2013 - 04:36 PM
Shorter belt will increase tension. Think of it like a guitar string. Are you trying to move the charger with the belt on to increase tension or are you fixing the pulleys and then rolling on a belt? Also are you using a stretch and tension belt?
#5 minivanman8
minivanman8
  • 426 posts
Posted 08 September 2013 - 04:50 PM
Its a belt supplied by vmax.  The crank and charger pulleys are obviously fixed and there is a third moveable pulley to tension the belt, hence I can't see how a shorter belt will help any.....I will still have to adjust the third pulley to get the tension.
I have now managed to get it tight enough anyway.
My concern now is the 'tappety' noise!
#6 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 09 September 2013 - 09:13 PM
I just lean on the tensioner with my body weight and it usually is about right
#7 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 11 September 2013 - 11:27 AM
Tappety noise, it may be the actual rotors within the charger making this sound?
#8 minivanman8
minivanman8
  • 426 posts
Posted 11 September 2013 - 07:05 PM
I managed to push on the tensioner with a hammer handle and get it better that way.
Hmm. to be honest a knackered 'charger would almost be the best outcome.
#9 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 11 September 2013 - 08:45 PM
If you take the charger off and spin it by hand you should be able to feel a clunk if the bearings have gone or the coupler is worn in the nose.
#10 minivanman8
minivanman8
  • 426 posts
Posted 11 September 2013 - 08:48 PM
Charger span over free and easy when it was off during the engine install....
#11 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 11 September 2013 - 09:08 PM
Should be ok then, you would be able to feel the clunk when spinning it, is it a supercharger off ebay?
#12 minivanman8
minivanman8
  • 426 posts
Posted 11 September 2013 - 09:09 PM
No. It came with my van. Originally a Vmax unit.
#13 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 11 September 2013 - 09:23 PM
Hopefully being a vmax unit it should be fine as i think stuart reconditions them before sale (i think)
Can you tell where the noise is coming from? video?
#14 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 18 September 2013 - 07:59 PM
I threaded my tensioner bolt in the the alloy of the charger whilst trying to tighten it. I had to tap a new thread, but it was never going to hold as well ever again, so I devised a way of holding the tensioner rock solid and fully adjustable, by using a large marine grade eyelet on a long thread that bolts into a hole already in the charger casing. Works a treat. If your interested I'll take a pic
Edited by HUBBA.HUBBA, 18 September 2013 - 08:00 PM.
#15 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 19 September 2013 - 09:54 AM
I'd be keen to see it! My s/c belt does slap around a bit at higher rpm and is on the standard pulley size.
