Spindle Bushes
14 replies to this topic
#1 jpw1275
jpw1275
  • 2,803 posts
Posted 07 September 2013 - 01:45 PM
Hi...... Is it possible to take the spindle bushes out of a su carb yourself at home without any special tools and refit new ones?
Cheers James
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 07 September 2013 - 02:59 PM
Which carb?
AC
#3 jpw1275
jpw1275
  • 2,803 posts
Posted 07 September 2013 - 03:23 PM
hi ac..... sorry... twin 1.25" su's
cheers james
#4 jpw1275
jpw1275
  • 2,803 posts
Posted 07 September 2013 - 03:25 PM
im wanting to refurb a set but i see no point in new gasket kits etc if the spindle bushes maybe worn
cheers james
#5 carbon
carbon
  • 2,590 posts
Posted 07 September 2013 - 04:49 PM
Often it is the spindle which gets most of the wear, have you checked the fit of a new spindle in your existing HS2 bodies?
Replacing the bushes is reckoned to be a tricky job, as the body needs to be drilled out then reamed to size for interference fit with the OD of the bush. This has to be done so that the bushes are in exactly the same location as the original holes for the spindle, and aligned. Not trivial.
#6 jpw1275
jpw1275
  • 2,803 posts
Posted 07 September 2013 - 05:43 PM
hi carbon.... no i havnt tried the new spindles in as im waiting for a full rebuild kit to arrive.... how will i know if there is wear in the spindles... am i looking for movement within the bushes with just the spindle in place and not tightened up etc
cheers james
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 07 September 2013 - 05:52 PM
HS carbs need machining as shown here;
#8 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 07 September 2013 - 05:54 PM
Basically in line drilling and reaming. Happy to do this for you £30 the pair inc return postage, you need to post you butterfly's spindles and bushes together with the carb bodies.
AC
#9 jpw1275
jpw1275
  • 2,803 posts
Posted 07 September 2013 - 06:01 PM
cheers for that ac.... i will be in contact when i have everything in hand
cheers james
#10 jpw1275
jpw1275
  • 2,803 posts
Posted 07 September 2013 - 06:03 PM
ac.... am i better vizzarding the spindles before or after the rebushing
cheers james
#11 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 07 September 2013 - 06:50 PM
Fit bigger carbs instead.
AC
#12 Scoop77
Scoop77
  • 508 posts
Posted 07 September 2013 - 07:12 PM
Vizarding is much cheaper!
Do it when you get them back.
#13 Scoop77
Scoop77
  • 508 posts
Posted 07 September 2013 - 07:13 PM
Love the use of the old head :)
#14 jaydee
jaydee
  • 8,565 posts
Posted 07 September 2013 - 07:41 PM
AC is right, you can work the carbs to the point it wont even sit on idle but a bigger carb will still outperform it..
#15 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 07 September 2013 - 09:43 PM
Its not the airflow that holds the engine back its the speed of the pistons in the carbs that is the limiting factor in the operation of the SU. The only way around this is larger pistons which means larger carbs.
AC
