I thinks its just your mini wanting to be a strawberry
Depressed...tiny Little Bumps On Cars Paint...
#16
Posted 03 September 2013 - 04:57 PM
#17
Posted 03 September 2013 - 07:24 PM
You may find they go right back to the metal, microblistering can also be caused by water or contaminants which can happen between the metal and primer or the primer and paint, thankfully its not the dreaded rust! (well shouldnt be) and as above is the way to fix it
I'm with Alex on this, micro blistering caused by water in the paint or primer. The only thing with this is to sand it right back to bare metal.
The reason here is if it is the primer then rust will form on the metal.
myredmini suffered this very problem and so have i. Not good news i'm afraid.
#18
Posted 03 September 2013 - 07:27 PM
#19
Posted 03 September 2013 - 07:55 PM
where did you get the car from? been imported from the UK recently?
Bad painting equipment and technique has caused this and it has been exaggerated by the large change in climate.
Seen this many many times.
This will go right back to the metal so the only real solution is to rub it all off and start again.
#20
Posted 04 September 2013 - 12:48 PM
#21
Posted 05 September 2013 - 05:20 PM
car covers really help towards this too :)
#22
Posted 05 September 2013 - 08:57 PM
I dont think that humidity, looks more similar to silicone bubbles, maybe something wrong between coats its causing reaction.
#23
Posted 05 September 2013 - 10:58 PM
Edited by mrbridger, 06 September 2013 - 06:17 AM.
#24
Posted 05 September 2013 - 11:39 PM
Definitely this, I've had it on a cam-cover I sprayed
contaminants, not necessarily water, between the layers of paint/primer
#25
Posted 06 September 2013 - 01:52 AM
