New 1312Cc Engine Lifter Knock?
engine
45 replies to this topic
#1 hotwheels
hotwheels
  • 196 posts
Posted 01 September 2013 - 02:09 PM
I just got my new motor installed and ready for 1st start..i get it started and cylinder 1 and 2 arnt firing and they Are getting spark and gas, , so its running on 3 and 4 cylinders, besides that im more worried about the knock im hearing wen it is started coming from the back side of the block under the exhaust manifold on cylinder 3 and 4 side..??(could it be a lifter or cam wearing in?? idk??) all my valve clearance are set to spec as i was told by the company i bought it from (valve rocker 0.016 spec on 1.5 minisport roller rockers, on 1275 A+ bored 40+. and im 85 % positive that the timing is dead on or atleast off a little bit, i have it at 12 degrees BTDC right now. i thought mayb it was 180 degrees off. so i tried it the other way to still nothing.
CARBS- im running used twin su hs4
compression test - 160 psi in all cylinders!!!
please gimme ur input!
heres a link of pics on my current project and the link of the motor i purchased
https://www.facebook...49597956&type=3 PICS
http://cgi.ebay.co.u...E:X:RTQ:GB:1123 ENGINE
i do have a clip of the sound
thanks Derek
Edited by hotwheels, 01 September 2013 - 02:28 PM.
#2 sledgehammer
sledgehammer
  • 3,094 posts
Posted 01 September 2013 - 02:52 PM
I would check tappets
then check compression
my first guess is head gasket
but it does sound more metallic
are you getting oil to the head ?
#3 hotwheels
hotwheels
  • 196 posts
Posted 01 September 2013 - 03:09 PM
thanks for the reply
my engine does not have the 2 tappet covers, its a solid block back there..that makes it tough cause not i cant see the lifters hmmm
my compression on all the cylinders were 160 psi on the dot.
i had it started with the valve cover off the other day and there is oil being pumped up to the head, i will do this again to see if there actually being pumped through all the holes.
and there is little signs of metal shavings i found on  the inside of the valve cover!?!?!
#4 Stevie W
Stevie W
  • 1,201 posts
  • Local Club: P&SMOC
Posted 01 September 2013 - 06:34 PM
Hi,
1.5 ratio roller rockers can and do foul the rocker cover as I've found out!
Look at the rear inner face of your rocker box and the same on the rockers and see if there has been contact, especially the 2 outer rockers.
I had to take my Dremel to the rear face of the rocker box to gain clearance (tall alloy finned type rocker box, same as yours).
If your engine is only running on 2 cylinders, double check that fuel is getting to, and out of the carb connected to your non-firing cylinders.
Hope this helps,
Cheers, Steve.
Edited by Stevie W, 01 September 2013 - 06:38 PM.
#5 sledgehammer
sledgehammer
  • 3,094 posts
Posted 01 September 2013 - 07:34 PM
+1 on the rockers touching - can be made worse if the head has been skimmed , and no shims under rocker posts
to test whip rocker cover off - if still noisy - should be easier to find problem
also possible - but less noise - a push rod bent
with the compression's being good - as above with carb or air leak on 1&2 - or pipe off / split
check dash-pot pistons move freely - esp if stored for a while - they can stick messing up fueling
what engine vent are you running - just the timing cover ?
Edited by sledgehammer, 01 September 2013 - 07:36 PM.
#6 hotwheels
hotwheels
  • 196 posts
Posted 02 September 2013 - 12:23 AM
Stewie W i have checked under my valve cover and there is no noticable wear marks to b found also still make noise when engine is running with valve cover off ;/
also cylinder 1 and 2 is firing now but kinda soflty if that makes sense, like it doesnt fire as good as 3 and 4 does.. hmmm
Sledgehammer i will check tomorrow for a bent push rod and also my twin carbs are used and hard to tune especially since the chokes keeps getting stuck open.. and are not in sync with each other
i think i want to ditch the twin hs4's to get just 1 su Hif6 1 3/4 carb, do you think the 1300 engine would run fine on just that???
also i made a make shift engine vent from my old engines back tappet vent cover, just a little bit of cutting and welding. i will install it tomorrow and have a picture of it.. also do i put a filter on the tip of the vent or do i run a hose somewhere?? mayb to the carb?? not really sure how that workss
but anyways thanks for the replys guys!!
IM GETTING CLOSER!!!
#7 hotwheels
hotwheels
  • 196 posts
Posted 02 September 2013 - 12:31 AM
also on my twin carbs, one carb has way more suction/ intake air flow than the other one, like a ton more and thats the one thats on cylinder 1 and 2 side!! but my intake manifold is wide oped to both carbs and both inlets to the engine so its all sharing?? i would think
#8 jaydee
jaydee
  • 8,565 posts
Posted 02 September 2013 - 09:17 AM
Twins need balancing, lots of infos about doing this on the web.
http://www.minimania...ype_Carburetors
Your engine is running way too rich, you'll bore wash it by running it this way. Correct it asap.
Also remove the rocker cover and run the engine a few secs without the cover, you'll easily see if the knocking is the rockers hitting on the cover.
#9 Cooperman
  • 23,201 posts
Posted 02 September 2013 - 11:48 AM
Sounds like carb mis-match/balance is one problem and, possibly, the high-lift rockers are hitting the rocker cover as problem no.2.
Set static timing for initial start-up to 6 to 8 degrees BTDC, 12 degs is far too much advance and can cause 'pinking'. Once started adjust the ignition a bit to give optimum running. Balance the carbs accurately with a carb balancer or, if you don't have a balancer, a length of rubber hose in your ear and to each carb mouth until it 'sucks' with an identical hiss at 1200 rpm.
#10 hotwheels
hotwheels
  • 196 posts
Posted 04 September 2013 - 12:47 AM
Sledgehammer i snapped a pic of my vent breather, where exactly do i connect the hose too?? carb?
Jaydee i was rained out today but hopefully tomorrow it will b dry and i can start it without the cover to verify the knocking,
and yes my carbs are deff offf, i order that unisyn tool carb balancer today, and that will help me alot!!
Cooperman i will set my static timing back to 6-8 degrees BTDC tomorrow
thanks for your help guys!!
Edited by hotwheels, 04 September 2013 - 12:49 AM.
#11 sledgehammer
sledgehammer
  • 3,094 posts
Posted 04 September 2013 - 04:11 PM
Sledgehammer i snapped a pic of my vent breather, where exactly do i connect the hose too?? carb? -
get someone on here to confirm this before connecting up vents - as I am unsure
looking at the vid - you have two pipes blanked off , on the carb
these go to a tee - then on to the vent you show in the pic (when fitted)
a pic here http://www.theminifo...in-hif38-carbs/
thanks to beaubrad
I don't know whether you should sync the carbs first thou
Edited by sledgehammer, 04 September 2013 - 04:17 PM.
#12 hotwheels
hotwheels
  • 196 posts
Posted 05 September 2013 - 12:33 AM
yes i really need to sync them but there kinda crappy but when that unisyn tool comes in ill give it a whirl!!!
and if that fails mayb 1 single HIF6
heres 2 vids with it runinng without the cover
#13 hotwheels
hotwheels
  • 196 posts
Posted 05 September 2013 - 12:34 AM
also the pushrods are not bent
#14 Da11yn
Da11yn
  • 72 posts
Posted 05 September 2013 - 07:11 PM
if you use a couple of foot of hose pipe with one end to the ear and move the other around the engine bay you should be able to pin point the knocking noise more accurately.
hard to tell from the a video but other options for knocking noises could be blowing exhaust manifold or fan hitting timing cover breather.
#15 sledgehammer
sledgehammer
  • 3,094 posts
Posted 05 September 2013 - 10:02 PM
I'm sure it isn't - but in the first vid - look at the fan ?
when I first see it - I thought the fan was in time with the knock / strobing almost
does anyone else see that ?
may be an idea to slacken off the fan belt to eliminate it ?
