Air getting in will allow the oil to drain back down the pick-up pipe, like taking your finger off the end of a pipette. Still a mystery where the air got in though,
Another Oil Pressure Problem - New Engine Build - Advice Needed
#31
Posted 09 September 2013 - 09:55 AM
#32
Posted 09 September 2013 - 10:23 AM
I think the issue was a sticky relief valve not fully returning.
#33
Posted 11 September 2013 - 08:19 PM
Hi and thanks fro the replies both.
A small and hopefully, final update. I thought I would add this in case anyone else has a similar issue.
I took the car out for a run, initially happy with the new pressure. After around 15 mins, with the oil nice and warm, the pressure had dropped off to about 50psi when running. Wasn't too happy as I thought the drop was a bit excessive given the run time since new bearings.
The weird thing was, when I stopped at a junction, it went back up to 75psi at idle!
Set off again and dropped to 50 and stayed constant.
More web searching and the opinion on the bearing relief valve varied, so I put the standard one back in and I have 75 at start up. 70 - 75 running dropping to 50 at idle even after a short run on the motorway. I've ordered a new valve as the one I have has a couple of marks, but I think I may now have cured the problem.
I did find a note on Calvers web site which showed a similar issue with the problem traced to a screwed in oil plug. I'm not at the stage yet where I want to pull and strip the clutch case to check. (I have the standard gallery plugs) But one to note as it's the only plausible explanation I have seen relating to the some problem I had.
http://www.calverst....lugs(bungs).htm
Regards
Steve
Edited by stevede, 11 September 2013 - 08:23 PM.
#34
Posted 12 September 2013 - 04:50 PM
Steve,
Good to hear you have sorted the problem, just a quick word of caution about using the ball bearing relief valve in cold winter weather.
I was running one of these for about a year until one very cold morning the high pressure blew out one of the oil gallery plugs (was showing well over 100 psi on the gauge, with 15/50 oil). I think the problem is that the spring has less travel with the ball instead of the plunger, and can get coil-bound before the relief port is fully uncovered.
#35
Posted 12 September 2013 - 08:17 PM
Steve,
Hi Carbon, many thanks for your reply.
I have taken the ball out as it was giving strange readings. I received the new std plunger today so will fit over the weekend.
Regards
Steve
#36
Posted 13 September 2013 - 08:54 AM
Yes the balls can have this effect,
its due to them doing somthing akin to the "malteeser trick"
see how it bobbles about.... I belive this causes the eratic pressure.
I have had good experience with adding a cup and pin arangment to keep the ball ans spring aligned, similar to what avonbar used to offer
http://www.avrclassi...duct/?pid=47904
easier just to use the std part though, and maybe slim it down slightly.
#37
Posted 09 October 2013 - 10:01 AM
Useful thread. I'm rebuilding a block & am very interested in all the options & precautions to take.
#38
Posted 09 October 2013 - 10:24 AM
#39
Posted 09 October 2013 - 01:05 PM
Have run the engine for around 150 miles now. From cold, the oil light is on for perhaps 2 seconds and after that goes out immediately if the engine is stopped & re started. I haven't done the first oil change as yet so still running thick 20/50.
Whilst running, and even after a short motor way run and some rush hour start stop, the pressure has remained constant at 50psi idle rising to 70 plus above 2500rpm.
#40
Posted 13 October 2013 - 04:24 PM
sounds good to me....
