Thermostat, Is It Upside Down ?
Best Answer sonikk4 , 27 August 2013 - 12:18 PM
Yes its upside down. Switch it over right side up.
Go to the full post
14 replies to this topic
#1 leeuk
leeuk
  • 681 posts
Posted 27 August 2013 - 12:17 PM
Hiya guys, I thought I would take a look at my mini as I have been having problems with the engine getting hot,
Well I started off by having a look at the thermostat and I think the engine builder has put the thermostat in upside down,
Am I correct in saying this as after looking in the Haynes manual the thermostat is put in the other way around,
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,076 posts
  • Name: Neil
Posted 27 August 2013 - 12:18 PM   Best Answer
#3 Cooperman
  • 23,325 posts
Yes, that is indeed fitted upside down!
One might wonder what else the so-called 'engine builder' has done wrong if he can make such a basic error!
#4 leeuk
leeuk
  • 681 posts
Posted 27 August 2013 - 12:23 PM
What a k-nob, Excuse my French,
Would this of caused any damage to my engine,
Its been running like this for 600mls and I have had it on the rollers too, Not a happy chappie
Edited by leeuk, 15 October 2013 - 12:17 PM.
#5 sonikk4
sonikk4
  • 16,076 posts
  • Name: Neil
Posted 27 August 2013 - 12:29 PM
What temp has your car been running at?? you may have been ok.
#6 leeuk
leeuk
  • 681 posts
Posted 27 August 2013 - 12:32 PM
Its never been into the red as I have shut it off before so although it has been past the last white marker just before the red.
#7 Frisco
Frisco
  • 417 posts
Posted 27 August 2013 - 12:52 PM
If you didn't let it overheat it should be fine
#8 leeuk
leeuk
  • 681 posts
Posted 27 August 2013 - 12:58 PM
Right then im off to mini spares for a new gasket, I may as well pick up another thermostat while im there,
Any suggestions on what temp stat I should be using for my 1380, Its currently a 88*c stat ?
#9 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 27 August 2013 - 01:14 PM
i think 88 degrees is hottest. my engine was struggling to get warm with a 70 something so I fitted an 88... I noticed a loss of power and tone of the engine.
I've now opted for a 82 which seems alright, with the needle always half way up the gauge.
#10 daenesh
daenesh
  • 423 posts
  • Local Club: Classic Car Owners Group
Posted 27 August 2013 - 01:26 PM
82 should be fine
#11 Orange-Phantom
Orange-Phantom
  • 614 posts
Posted 27 August 2013 - 01:59 PM
I'd recommend the Kligersil Gaskets.  Probably the best you can get for the thermostat housing.  :-)
http://www.moss-euro...teIndexID=18948
Oh and on the subject of thermostats I'd only run a 74c on a race engine as max power from an a series is generated around 70c.  With a 74c thermostat in a road car the engine oil is not as likely to get up to a high enough temperature to boil of the contaminants i.e. water.
From the evidence that I have seen and speaking to the likes of Peter Vickers and AC Dodd the sweet spot for an Engine thermostat in the UK is 82c with the consensus to maybe swapping it to a 88c in the winter if you heater doesn't get hot enough!
I run an 82c in my 7 port 1380, which runs fine.
Also and nice graph illustrating the same thing.
http://www.carnut.co...blin/cool3.html
The 88c thermostat replaced the 82c thermostat in the UK in 1976 due to tightening emission regulations.
#12 leeuk
leeuk
  • 681 posts
Posted 27 August 2013 - 02:07 PM
Cheers guys, I did opt for the 82c I shall drop it in now and hopefully this will be the end of my problem ;-)
#13 leeuk
leeuk
  • 681 posts
Posted 27 August 2013 - 04:29 PM
Just to let you guys know that all seems to be fine, The temp is now staying between the 2 white lines, I can now venture out further than the next town lol ;-)
Thanks again.
#14 daenesh
daenesh
  • 423 posts
Posted 28 August 2013 - 12:26 PM
brilliant :)
#15 Orange-Phantom
Orange-Phantom
  • 614 posts
Posted 28 August 2013 - 12:56 PM
Ace!
Just remember........ to have fun!  :D
