Wellers On A Metro
Posted 27 August 2013 - 10:39 AM
Ive thought about sticking some 12x5 wellers on my metro, but ive heard the offset is all wrong and causes the tyres to scrub? Is this really a problem or just hearsay?
Cheers,
Rob
Posted 27 August 2013 - 10:52 AM
Lewis will be here shortly, I would say you'd need spacers for the front to clear the calipers and it should be fine with some decent tyres
Posted 27 August 2013 - 11:43 AM
You can fit 12x5 wellers without problem, just be careful of the offset as metros use different offset than minis, the wheels tend to sit further in on a metro, but they should be fine. The only thing to watch out for clearance wise is the metal lugs on the front hubs
Posted 27 August 2013 - 12:39 PM
Posted 27 August 2013 - 01:32 PM
Does work with wellers but you can only go backwards and forwards
These are temp for mine to sit on whilst i re-furb the original steels and the fronts cach the most forward part of the arch, id say you'd have no issues if you did abit of hammering or raising of the hydro units as its not too much scrub
Cliff
Posted 27 August 2013 - 01:39 PM
Rob, how do you plan to make them fit since I believe your car is a Rover Metro? the PCD will be 95.25 as opposed to the Mini Weller PCD of 95.25?
Posted 27 August 2013 - 05:00 PM
Posted 16 September 2013 - 12:53 AM
Any suggestions on what fits and looks best?
Posted 16 September 2013 - 02:34 PM
Theres an offset quoted in this yee old post here: http://www.theminifo...es-it-all-mean/
Posted 16 September 2013 - 02:54 PM
Posted 16 September 2013 - 02:57 PM
Don't quote me on that being correct as it confused me a little as to wheather its mini or metro Offset, will the metro steelies have it on the band of the rim ? as i,ve got some without tyres in the garage i could have a ganders at for markings if you like, just to confirm
Posted 16 September 2013 - 03:00 PM
Posted 16 September 2013 - 03:15 PM
Right numbers/letters i,ve found are as follow in this order:
RM148A F2
Hopefully something there makes sense haha
Posted 16 September 2013 - 03:51 PM
Posted 16 September 2013 - 03:54 PM
Hahaha that makes two of us then , theres no other markings on them apart from a Dunlop logo so that only leaves the trusty Haynes manual to shed some light on this ....
