Dayummmmm!!! Magnum it is!
Wills Mini Special
#91
Posted 22 January 2014 - 11:02 PM
#92
Posted 22 January 2014 - 11:04 PM
Dayummmmm!!!
Magnum it is!
And they suck big stylee.
#93
Posted 23 January 2014 - 01:14 AM
#95
Posted 23 January 2014 - 07:52 PM
Spiffing!
Wish i knew where you got those inner sills.
They are exactly what i need!
Ben
#96
Posted 23 January 2014 - 08:04 PM
They look like m-machines.
#97
Posted 23 January 2014 - 08:07 PM
Spiffing!
Ben
As Dan says Ben they are M Machine. They are not bad as it goes, just the floor pan section was a bit of a pain.
#98
Posted 23 January 2014 - 10:50 PM
Spiffing!
Ben
Cheers.
I won't need the whole length as the new front pans have inner sills as part of the floor.
I would only need the back half from the cross member back so perfect!
Ben
#99
Posted 24 January 2014 - 10:00 AM
Impeccable techniques as ever Neil proper motoring with this one.
#100
Posted 24 January 2014 - 10:03 AM
great build! i suppose its only to be expected from admin though... ;)
#101
Posted 24 January 2014 - 05:21 PM
Looking good Neil
What did you use to get the welds so flush flapper / roloc discs ?
That section of the front floor pan came out really well
#102
Posted 24 January 2014 - 05:23 PM
I grind down with a standard grinding disc then use a flapper wheel followed by a roloc disc. I'm happy with the floor now but it was a faff to get right.
#103
Posted 24 January 2014 - 08:57 PM
Well before i finish up the arch close out area it was time to investigate the rust that was on and around the little felt mounting plate on the floor.
under that was more rust so a couple of surgical cuts later i got this
then out with the fresh metal to fabricate this
then it was welding time
followed by a little bit of grinding and a splash of zinc rich primer
Happy days so now i know that end is good.
#104
Posted 27 January 2014 - 07:50 PM
Due to a minor hiccup by M machine which has been sorted by them i had to move onto the doorstep.
This particular magnum panel was on a par with the rest of them........... poor so the folds were pretty bad but the width of the panel was actually good. So that was something.
I then used a combination of thick Ali bars, metal blocks and panel beating hammers to sharpen the folds to a point where i now considered it useable. So on it went.
Actually came up well apart from a slight bow. This will get sorted when i fit the outer sill.
#105
Posted 27 January 2014 - 10:43 PM
Fitted one to the lads car the other day NIGHTMARE it took ages the back of it where it bends up was the worst
So hats off to you for getting that to fit mate.
