Wills Mini Special
320 replies to this topic
#76 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 21 January 2014 - 09:10 PM
Ahh i see what you mean now Alex, nope thats how they come. That was copied off the original panel.
Ah, didn't realise that Just seen some pictures, How come they are like that?
#77 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 21 January 2014 - 09:12 PM
Its to do with the arch closeout panel i believe. It looks strange but thats the way it is.
#78 alex-95
alex-95
  • 6,078 posts
Posted 21 January 2014 - 09:18 PM
Oh, I made mine straight which seemed to have worked fine luckily :lol:
#79 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 21 January 2014 - 09:20 PM
I have got the two piece ones from M Machine for this car, a bit cheaper than Heritage.
#80 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 22 January 2014 - 04:51 PM
Finally the inner sill is in although only tacked.
However there is a fly in the ointment here with the front floor pan section. It does not match at all :mmkay:  :mmkay:
so a bit of fettling later i used a bit of the original floor to sort it out, again though only tacked in place
It will all be good tomorrow though.
#81 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 22 January 2014 - 05:24 PM
Hi Neil
Is this the MM panel 11.33.01.27 LH? If so can I ask what it cost including postage?
I am debating weather to use this or the half floor for my driver's side floor. The panel you used should do the job if its cheaper than the half floor it may save me a few quid?
The half floor is £75 inc P+P  http://www.ebay.co.u...=item43b12d0fb0
Jason
#82 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 22 January 2014 - 05:44 PM
Hi Neil
Jason
Jason I honestly don't know as Will the owner of the car bought them along with a load of other parts.
#83 Marco1972
Marco1972
  • 822 posts
Posted 22 January 2014 - 06:05 PM
I had the same fitting issue when I fitted that panel to my car
Unfortunately my old floor pan was toast so didn't have the option of slotting in a spare bit
Lots of head scratching and cursing I got a decent fit in the end
Edited by Marco1972, 22 January 2014 - 07:38 PM.
#84 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 22 January 2014 - 06:17 PM
Ohh dear sounds like the half floor cut to fit is going to be easier.  O_O
#85 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 22 January 2014 - 10:45 PM
Looking good Neil!
#86 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 22 January 2014 - 10:49 PM
Looking good Neil!
Cheers Dan i'm just a bit miffed the floor pan is so far out but other than that its not a bad bit of kit. It will be interesting to see how i cope doing this on Paddy as i want to keep the companion bins in place.
#87 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 22 January 2014 - 10:54 PM
I'm sure a man of your skills will manage just fine. I need to fabricate some of the sill strengtheners which spot weld to the inner sill and outer sill at each end. Also need to see what m-machine say about doorsteps, heard they now do their own so my dads popping in tomorrow hopefully to ask. then I can clamp everything up and hang the door to adjust everything before welding!
All good fun!
#88 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Excellent work as usual Neil.
I do look forward to your updates!
Ben
#89 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 22 January 2014 - 10:57 PM
Ben
Cheers Ben  :D
#90 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 22 January 2014 - 10:58 PM
All good fun!
Mate they don't them only the MK1's unfortunately. I had a chat with them the other week.
