Wills Mini Special
320 replies to this topic
#301 james_k
james_k
  • 15 posts
Posted 02 October 2014 - 10:07 AM
Just sepnt two days reading the whole thread and there's some amazing work gone into it. A real credit to you Neil!
I bought my first mini on the weekend after wanting one for years . Will have to carry out some repairs on it myself hopefully not to this extent though, also need to learn some welding skills first though.
Anyway keep up the good work Neil, almost finished
#302 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 02 October 2014 - 03:05 PM
Neil them there tabs you have put on.
Are they just folded steel?
Think of putting some on my removable front to add some strength that's all.
Yes Sal that's all they are, I did put a small curve on them as well to suit the contour of the two panels.
#303 Jemy
Jemy
    Starting My Mini Up
  • 1 posts
Posted 02 October 2014 - 04:41 PM
Just wanted to say thank you for sharing has given me loads of insight into what and how needs doing on mine. phenomenal job !
#304 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 02 October 2014 - 04:44 PM
No problem, glad it helps.
#305 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 02 October 2014 - 06:35 PM
On with the bulkhead repair, new repair section fabricate and heater support hook welded in place
and clamped in place ready for welding
welded in place and cleaned up
and in between doing that i did this
Paul busy tweaking the lip in place ready to be bonded together. His van certainly will be lighter inside.
So after that i had time to tack a filler rod to the bottom of the drivers door and this will be finished tomorrow
#306 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 03 October 2014 - 03:00 PM
So after a quick blast with the welder today i have finally finished welding this car.
Plenty of Frosts Cold Front
and you get this which is nothing to see
and not a ripple in sight so happy days. Just need to seam seal the whole car so that's a job for next week.
#307 james_k
james_k
  • 15 posts
Posted 03 October 2014 - 05:16 PM
Might be a daft question but how come you've welded a welding rod to the bottom of the door? Have you used it as some kind of filler?
#308 Carlos W
Carlos W
  • 10,114 posts
Posted 03 October 2014 - 05:18 PM
You can tighten up door gaps really nicely with them
#309 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 03 October 2014 - 05:53 PM
As Carlos has said by using a welding rod welded to the door you can get decent door gaps rather than having gaps you can walk through.
#310 Marco1972
Marco1972
  • 822 posts
Posted 03 October 2014 - 08:00 PM
Top notch job mate
Been a really informative build going to miss following this one
Looking forward to paddy now
#311 acky
acky
  • 84 posts
Posted 02 February 2015 - 02:23 PM
just awesome Sonic, the end result is making re-assess what ive done
what tips do you have for plug welding ??
I have a joggler with a 5mm punch, is that too big a hole or ok ?
What do you use for sanding in tight positions ??
#312 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 02 February 2015 - 04:13 PM
Most of the time I drill a 1/4" holes for plug welding but 5mm will be fine but do plug weld on high power.
For tight gaps I always use my right angle die grinder and carbide burr.
#313 clubman91
clubman91
  • Just Joined
  • 137 posts
Posted 03 March 2015 - 12:24 AM
Had a look through this build, Great work...Shame will not see the rest of the build.
How can i get a set of the door steps?
Cheers,
Mark.
#314 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 03 March 2015 - 08:48 AM
I currently don't have any spares plus I'm not sure as and when Alan can make another batch as he has to set up his press.
#315 mk1leg
mk1leg
  • 9,343 posts
Posted 03 March 2015 - 09:46 PM
Wow this has come on a long way......great skills......... :highfive:
