Wills Mini Special
320 replies to this topic
#16 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 23 September 2013 - 12:38 PM
Lovely Mini Special project i had one of these, but the (Leaf Silver one) which was meant to be my first car, and had to sell it when i needed funds which was gutting :( was just ready for the paint all the hard work had been done, the new owner has since finsihed it and its stunning.
 I will ne keeping an eye out on this build :)
good work so far...
Edited by minimissions, 23 September 2013 - 12:39 PM.
#17 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 23 September 2013 - 06:58 PM
A bit more repair work today on the inner wings.
L/h inner wing at the front looked very iffy and covered in gunk along with the r/h inner wing.
L/h inner
R/h inner
Once the crap was off on the l/h inner i found this, some previous rust removal that had thinned the metal drastically
New metal in place
New metal welded in
Desperately needing panels now as there is not much more i can do apart from the old little repair on the roof guttering.
#18 okc78
okc78
  • 169 posts
  • Local Club: none so far
Posted 23 September 2013 - 08:25 PM
Hi sonikk4
I've not spoken to you before but thought I should take the time to thank you for posting and contributing.
Before I started my mkII project  I was lurking on the website and have been watching your work for a while, project erm and paddy. I've taken quite a few tips from you and its all helped inspired me to get the welder out and start dealing with the rot.
I look forward to seeing this one progress.
Cheers, Ollie
#19 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 23 September 2013 - 08:39 PM
Hi sonikk4
Cheers, Ollie
Glad the threads help out Ollie.
#20 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 24 September 2013 - 06:55 PM
Had a look at the roof today and all is not well.
The guttering on the r/h side was somewhat crispy
so a bit of cutting and metal fabbing i ended up with this
There was rust in other places as well some not so obvious until the paint came off
paint off
so instead of chopping out a large section i individually ground back each area of rust with a die grinder
with all of the rust ground out i then filled with new metal
The same process was applied here as well
This took a lot longer to do and was a real pain in the backside. Carbide burrs of different shapes and roloc discs plus the use of a flat wire wheel got the surface rust out.
This in turn got polished back with a DA sander then treated so no more rust there. I really did not want to have to cut that lot out. (not shown in this picture)
#21 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 24 September 2013 - 07:03 PM
Good work neil. Is the anti-warping  stuff reusable?
#22 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 24 September 2013 - 07:06 PM
Yes it is apparently. If it dries out you can add more water to it. I did find you need to use more than what i did there as there was some heat transfer. Still trial and error at the mo so i also had a wet cloth to hand as well.
#23 okc78
okc78
  • 169 posts
Posted 03 October 2013 - 07:42 PM
Hi, have you got a link to this anti warping clay your using? I've not seen it before.
I've been using the wet rag technique as you mentioned and some sheets of copper but I found the copper affects the penetration of the weld, I like to be able to grind it back on the inside as well. This clay your using looks more user friendly.
Thanks, Ollie
#24 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 03 October 2013 - 07:55 PM
This is the link to their page
http://www.frost.co....ront-414ml.html
#25 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 04 October 2013 - 06:41 PM
very nice, inspiring to see some of these techniques
#26 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 11 November 2013 - 09:32 PM
Finally received all of the panels for the mini today. Disappointingly the doorstep panels from M machine are not their own but from Magnum so about as much use as a chocolate tea pot.
#27 Russw
Russw
  • 107 posts
Posted 12 November 2013 - 08:45 AM
Looking good Neil. I've just bought heritage door steps as you mentioned the m machine ones might be magnum, I didnt think they were that expensive either. Maybe a swoops in order?
#28 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 12 November 2013 - 10:55 AM
Yep I need to talk to Will as these will be a waste of time. Not sure what's going on with M Machine as they say the new steps are their own pressing.
#29 leadly
leadly
  • 779 posts
  • Local Club: [] D.C.M.O.C []
Posted 14 November 2013 - 03:28 PM
Ah, didn't realise cold front was reusable! Cracking work as always!
#30 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 18 November 2013 - 07:13 PM
Nothing much done to the car but i did get this
6ac5d773-7612-47e5-bf6e-367d0c469c3e_zps
and made this,
3abfbba8-957a-439c-809c-65749dcb7933_zps
so any clues as to what it is
